1972 Chevy C10 - Heater Core
What's the simplest way to replace the heater core? Can you do it all from inside the cab?
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: 1972 Chevy C10 - Heater Core
If your truck has A/C you can, but if not, no you can't. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Most people including myself drop the right front inner fender to gain access to all of the bolts to remove the housing containing the core. Some can do it without, but that requires more patients than I have most of the time..
I have the inner fender out...
Without A/C, I pulled mine by removing the R/H hood hinge first. other wise the blower motor doesnt have enough clearance to pull away from the fire wall. The hardest part is the bolt located just under the blower and above the fender. Get a new gasket set while you have it out. You can pickem up for under 20 bucks.
I haven't even looked at any of it yet but does the housing unbolt from inside the cab or in the engine bay? I'm getting mixed responses.
I was hoping that I could pull the housing from inside the cab and the heater-core will come out from there, with just the tubes pulling through the firewall. |
#8 | |
There are 4 bolts that pass through the firewall and the outer housing on an A/C Truck. You have to take those loose from the engine side. You also will have to remove the A/C duct selector from the inside. It is the one mounted to the heater core housing. Then unplug the wires to the high speed fan relay and the resister inside the housing. Then you should be able to pull it to change the core. A/C trucks are different than non A/C trucks. WES
#10 | |
