01-15-2013, 04:12 PM | #1 |
1972 Chevrolet C10 OEM fuse block & under dash wiring harness no guages no AC
Entertaining all offers!!!
This is an interior wiring harness and fuse box that was removed from a running a driving 1972 Chevrolet C10 pickup. The truck did not have gauges, it had "idiot" lights. It also did not have A/C. This harness will fit other 67-72 chevy trucks, but I cannot guarantee anything. I cleaned the harness with soap and water after I removed it from the truck. This harness can be modified to work with stock gauges. I can do this modification for an additional charge if needed. As mentioned above, this harness was removed from a running and driving truck, but it is not without issues: 1. In the photos, there is some heat damage to the headlight switch plastic plug. The wires do not appear to be damaged and the headlights were functional. 2. In the photos, the connector for the dimmer swich is missing. I believe I have one from another harness that I can install 3. The black wire for the wiper motor has had a crimp connector installed. 4. The grey wire for instrument and panel lights has been cut. I did not think to check if the instrument lights were working before I removed the harness and I didn't have a wiring diagram at the time. 5. There is a brown wire that has a terminal but no connector. From my research, my best explanation for this wire is circuit #25. My wiring diagram explains circuit 25 as "GENERATOR OR GENERATOR ARMATURE TO VOLTAGE REGULTOR "A" (INCLUDES GENERIC TELLTALE CIRCUIT OR REGULTOR TO IGNITION SWITCH (TRUCK) $75 shipped USPS to the lower 48 sates, you cover the paypal fees. Last edited by WIDESIDE72; 11-03-2013 at 09:40 AM. |
01-21-2013, 03:25 PM | #2 |
Re: 1972 Chevrolet C10 OEM fuse block & under dash wiring harness no guages no AC
photos
01-21-2013, 03:30 PM | #3 |
more photos
01-25-2013, 12:57 AM | #4 |
Any offers?
02-07-2013, 03:54 AM | #5 |
ttt
03-09-2013, 02:09 AM | #6 |
ttt
03-28-2013, 07:45 AM | #7 |
Ttt
Posted via Mobile Device |
03-31-2013, 09:01 PM | #8 |
Ttt
07-05-2013, 08:47 PM | #9 |
Still Have this wiring harness? I am located in Spokane, WA. i'll send this to my brother. He has paypal. Thanks!
07-05-2013, 09:00 PM | #10 |
11-03-2013, 09:43 AM | #11 |
Ttt
I also have a fuse box and harness for trucks with gauges that has no defects $100 shipped Inside underdash ac harness one burnt connector $30 Buyer covers fees if paypal |
11-09-2013, 06:21 PM | #12 |
hi, i need just the fuse box, can you split? shipped to miami, fl
best regards |
11-09-2013, 07:38 PM | #13 |
