Old 01-15-2013, 05:18 PM   #1
wayno
Deep rust pocket
So I have some spots - mostly where my rear fenders attached to the sides where I haven't rusted clean through. I've wire wheeled them out and sprayed some rust preventer (not sure what I think of that stuff) - and then hit it with some self etching primer. Now I'm wondering if I should have just pulled out my welder and attempted to fill some of the deeper ones in (realizing I'd probably blow straight through). Just worried about bondo-ing in some of these - am I just being @n@l?
wayno is offline   Reply With Quote
Old 01-15-2013, 06:39 PM   #2
62 Barnfind
62 Barnfind's Avatar
Re: Deep rust pocket
I had the same problem with mine. I took the whole bed apart and sent it to the sand blaster. I cut out the bad and welded in new metal. For the rust pits I primed and filled them. The blasting removed all the rust and then used spot putty because the pits were not that bad I just had alot. This is when I brought it back from the blaster and welding in my new strips and filling the small rust pits. Now the bed is smooth and waiting for paint. i hope this will help!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-15-2013, 09:04 PM   #3
wayno
Definitely a help - wanted to make sure I was on the right path and there weren't any more tricks out there. Thanks for letting me I'm headed in the right direction. Panel is looking good... looks like a lot of hours already into it.
Old 01-16-2013, 11:28 AM   #4
62 Barnfind
Here is what my bed looked like to where it is now. As you can see I had a bunch of rust. I didn't think I would fix it all. But I think it came out good. Take your time and replace the metal that you need to and treat and fill the rest.
John Z
62 Barnfind
