Big Block, tall valve covers and a heater?
I know some of these series trucks came with big blocks. From what I have read you may have to either beat your firewall out or move the motor forward for the tall valve covers. Will the heater box be an issue with tall valve covers?
Re: Big Block, tall valve covers and a heater?
My dad's '69 has a 454 w/stock valve covers and the passenger valve cover has plenty of room around the heater box, so I wouldn't see why tall valve covers won't fit.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Here's a picture I found with tall valve covers. looks like plenty of room to me...
I have a big block with tall valve covers in my 68 I have no clearance issues by the heater box or my firewall. I could see having clearance problems only if you are using the 6 cylinder mounting holes
Posted via Mobile Device |
#5 | |
By 6 cylinder mounting holes I assume you mean the rear two correct? Do you have pics? |
yes you are correct, this is the only pic i have at the moment the truck is in storage for the winter if you are looking for something specific let me know i can go to were it is stored and take some more
Is that a short water pump setup on there?
no its a long water pump setup, i would of prefered the short due to the crank pulley being very close to the crossmember
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
The trucks in the pics on this thread all have no power brakes. Imthink you my have a clearance issue with a BB truck that has the stock 11 inch brake booster. Ive been wanting a set of Edelbrock Elite valve covers and I believe they are 5 1/2 inches high and I've measured and dont have that much clearance from the stock pb booster on my truck.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Not sure exactly how tall these valve covers are, but there aren't stock and you can see the lack or room between the driver side cover and the booster.
Tight fit on my old 72 but they did fit.
Florida Edition
![]() ![]() Join Date: Oct 2010
On a factory BB with AC the alt (on the drivers side) is a real p.i.a. with the stock brackets and tall covers but they are only required with a roller valve train.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
#13 |
I have also seem some bbc have alternator bracket interference with stock valve covers.
#14 |
![]() Join Date: Jan 2002
I installed my motor and tranny in my 72 with factory a/c and power brakes. It was a huge PITA but it does fit. If you have power brakes, I would suggest dismounting the booster for the install.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
