01-15-2013, 08:24 PM | #1 |
"something witty here"
What starter for sm465
I just got done putting in my sm465 and my old auto trannies starters nose cone won't fit in the bellhouse. Is there a different starter for the manual transmissions?
Posted via Mobile Device Posted via Mobile Device
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
01-15-2013, 08:54 PM | #2 |
Re: What starter for sm465
The cast iron bellhousing uses a bellhousing mounted starter. I ditched mine and went with a Hitachi style mini-starter. This is the one WITHOUT the additional support in the front of the bendix gear. This is a great mod IMO since you can ditch the GM starter with its propensity to heat soak.
01-15-2013, 09:24 PM | #3 |
Watch out for your cornhole !
Manual trans starter that bolts to the bellhousing on the left.
01-16-2013, 12:09 AM | #4 |
Ok so new mini starter it is. Thanks guys
