Old 01-15-2013, 08:53 PM   #1
rollin thunder
rollin thunder's Avatar
Cutting coils, tire clearence issues?
I was considering cutting a coil out if i remember correctly thats 2 1/2" roughly per coil. I am running 30x9.50 R15 tires, does anyone know if i would have any clearance issues? its still at stock height
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
Old 01-15-2013, 09:11 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Cutting coils, tire clearence issues?
if you only cut off one round you will have no problems at all.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 01-15-2013, 09:25 PM   #3
rollin thunder
Thanks Ghetto i suspected but never done it and wanted to make sure.
Old 01-15-2013, 09:30 PM   #4
ghettoluxury
no problem
Old 01-15-2013, 10:23 PM   #5
fastnloud
fastnloud's Avatar
I've thought about cutting the coils on mine for now as well. Does anyone know if you can still get a good front end alignment if you cut them?
fastnloud is offline   Reply With Quote
Old 01-15-2013, 10:33 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
depends on how much stud is available.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-15-2013, 10:36 PM   #7
fastnloud
fastnloud's Avatar
Alright, I've also found these springs, that are suppose to give you a 3 inch drop.
http://www.summitracing.com/parts/sum-g726
Would I be better off going with these?
Old 01-15-2013, 10:46 PM   #8
meatwagon83
meatwagon83's Avatar
why dont you just do it correctly? put spindles on it so it keeps the same suspension and steering geometry and the ride isnt rough
meatwagon83 is offline   Reply With Quote
Old 01-15-2013, 10:49 PM   #9
fastnloud
fastnloud's Avatar
I'm not too worried about the ride being rough. And at first I was planning on doing spindles and all, but I've decided I don't want to sink a lot of money into this truck like I have on others in the past.
Old 01-15-2013, 11:12 PM   #10
LEEVON
LEEVON's Avatar
There is nothing wrong with cutting a coil. You should be fine on alignment. I always do that before ordering lowering springs. Most of the time I'm happy with the ride, and I'm picky. Just make sure the rest of your suspension is in good shape.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-15-2013, 11:13 PM   #11
cochino12
It followed me home?
cochino12's Avatar
^^^^ x2
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-16-2013, 12:41 AM   #12
DREAMER1
DREAMER1's Avatar
Cutting 1 coil would not be a problem. Cutting more than that creates problems. And yes you can still get a wheel alignment afterwards. After I installed my drop spindles I had a hard time finding a place to get an alignment. Nobody wanted to do it for different reasons.
DREAMER1 is offline   Reply With Quote
Old 01-16-2013, 01:40 AM   #13
cory d
cory d's Avatar
the ride wont be rough, the half ton spring even with 2 coils cut are still squishy little noodles. i got my neg camber where i wanted with room to spare after 2 coils. i have 29" tire and i rub pretty hard some times. i wouldnt do more then 1.5 coils with 30" tires and half ton coils
cory d is offline   Reply With Quote
Old 01-16-2013, 02:13 AM   #14
KQQL IT
At the body shop.
KQQL IT's Avatar
I've always clipped 2 coils from 1 ton springs for my 1/2 ton drops. Put longer bolts in the upper A arms. And cut the bumpstop pad off.
Flipped the rear.
Wrong maybe... works for me.
Old 01-16-2013, 10:34 AM   #15
meatwagon83
this would probably explain why mine was rough, im not a half ton guy
