C100 connector and oil pressure
can this oil pressure switch be used for an aftermarket gauge?
anybody know what signal it has? only the one tan/wht wire on it. i know most people get oil pressure from the drivers side of the oil pan by drilling the 1/8"NPT hole and adding the sending unit there. i was just wondering if this sensor was usable.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
Re: C100 connector and oil pressure
Generally you should use the sender that came with your gauge for accuracy reasons. But you could try it I suppose, wouldn't hurt anything to try.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
yeah i was hoping someone knew what scale it was, like gas tanks are 0 to 90 ohm sending units, i was wondering if this would be the same.
you know 0-10vdc would equal 0-100psi, something like that. might not match my gauge but just wonder what it was.
