Old 01-15-2013, 10:46 PM   #1
TxRat
TxRat's Avatar
heater question and a dumb one
OK here's deal. This is the first early truck I have owned so I'm still learning.
My truck is a factory A/C truck that has two sets of controls. One is for A/C and the other is for heater.
I have these controls
The middle knob turns the blower motor on by pushing it down correct?
the left knob directs hot air to the defroster by pushing it down?
the right knob directs hot air into the cabin by pushing it down?
My fan doesn't come on but I also can't get the middle knob to move. It appears to be jammed. I just need to understand how it works before I tried to fix it. Has anyone else had the center knob jam up and what can I look at to repair it...
TxRat is offline   Reply With Quote
Old 01-15-2013, 11:01 PM   #2
chevyguys
I Got it BAD!
chevyguys's Avatar
Re: heater question and a dumb one
The blower motor switch is connected directly to the middle lever. You will probably need to repair the switch or find a replacement.
I had to repair mine (also a factory air truck), they are pretty easy to rebuild. I just (carefully) bent the small tabs back on the switch and popped it apart. I used electrical contact cleaner to clean all of the old dielectric grease out and polished all the contacts with my Dremel. Then used new dielectric grease and reassembled everything. Works flawless.
Build Thread: http://www.chevyguys.com
chevyguys is offline   Reply With Quote
Old 01-15-2013, 11:11 PM   #3
TxRat
TxRat's Avatar
OK thanks!!!
Old 01-16-2013, 01:41 AM   #4
Captainfab
60-66 Nut
You could also just replace the switch
Old 01-16-2013, 11:18 AM   #5
chevyrestoguy
chevyrestoguy's Avatar
Once you get the switch cleaned/replaced, make sure you double-check the smoothness of the cable. This may be the reason why the lever will not move. It's not uncommon for them to slightly corrode and bind. A stuck cable is the main reason why you see heater controls with broken levers. The cable levers aren't that strong, and if you're trying to muscle the lever, it'll break.
You can replace the cable, or you can soak it in PB Blaster or Kroil. When everything is operating as it should, the levers should move with very little effort. Make sure you lube what the other end of the cable hooks to as well. Some of the flapper doors can bind up too, a shot of PB to free them up and then a little spray grease to keep 'em lubed makes a big difference.
If you want to study up on the operating functions and switchology of the heater and A/C system, the factory manuals are excellent, especially the Factory Accessory manual. It shows the cable layouts and breaks down the full functionality of each switch.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-16-2013, 01:08 PM   #6
64fleetside
The air/fan cable is really long, and is prolly binding up-it attaches to the bottom of the heater box underhood.
64fleetside is offline   Reply With Quote
Old 01-16-2013, 01:22 PM   #7
chevyrestoguy
Good point. I have seen more than a few of those with just a slight kink in the cable that basically renders it completely bound up. Even trying to straighten it with a pair of pliers oftentimes doesn't make a difference. Once the inner wire in the cable gets kinked, you're almost better off to replace it.
My favorite cable is the one on the A/C trucks that controls the flapper on the backside of the heater box. You can only access it from the inside, and even then, it's a bear. You find a lot of the A/C specific heater boxes busted on the top lip that goes over the edge of the upper firewall because guys try to muscle them off because they don't know that there's a cable still connected that they can't see from the engine side of the firewall.
My build threads:
Old 01-16-2013, 02:46 PM   #8
vpersh
vpersh's Avatar
Just a little clarification: the "Heat" knob really doesn't direct air to the cabin. It regulates the temperature of the air.
Van Pershing
Tucson, Arizona
Idea Page
vpersh is offline   Reply With Quote
Old 01-16-2013, 06:26 PM   #9
TxRat
TxRat's Avatar
Thanks guys for all the tips/help. I'll dig into it and see whats going on with it..
Old 01-16-2013, 08:24 PM   #10
TxRat
TxRat's Avatar
OK I got the cable freed up. Fan still wont come on. Looking at the wiring the P/O cut the white wire and put a micro switch and inline fuse in it. Does anyone have a wiring diagram that includes the blower wiring so I can figure out whats going on. I plan on putting A/C in it this summer but until then I'd like to at least get the heater/defroster working...
Old 01-17-2013, 12:26 AM   #11
rustyrodknocker
You did run a temporary hot wire from the battery to the motor right? I always do this first only takes a second to make sure the motor runs.
rustyrodknocker is offline   Reply With Quote
Old 01-17-2013, 10:01 AM   #12
TxRat
TxRat's Avatar
Yea, I'll be doing that today, Ran out of day light yesterday. Does anyone know what the white wire is in the heater harness?
Old 01-17-2013, 02:56 PM   #13
McCoyAZ
McCoyAZ's Avatar
It doesn't get cold in Texas.
McCoyAZ is offline   Reply With Quote
Old 01-17-2013, 04:09 PM   #14
TxRat
TxRat's Avatar
HAHA yea your partially right. It doesn't get cold in Texas FOR LONG.
So here's what I found today, This truck is a factory A/C truck but the compressor and condenser are missing but all the under dash and controls are intact.
The fan was toast so I replaced it and found I did not have 12V to the fan repaired the wire going to the fan and now the fan comes on. There is a micro switch on the lip of the bottom of the dash that is wired into the fan control the turns the fan on and off but receives 12V from the factory fan switch? not sure why its wired in this way but I'm leaving it for now as it appears I only have one fan speed this way. I am adding A/C to the truck this summer so all this will be coming out then.
Thanks for the help guys, on to the next problem...
Old 01-17-2013, 10:46 PM   #15
vpersh
vpersh's Avatar
Here's a wiring diagram that might help:
http://persh.org/images/65Pickup/acwiring.jpg
Van Pershing
Tucson, Arizona
Idea Page
Old 01-17-2013, 10:53 PM   #16
TxRat
TxRat's Avatar
Thanks!!!
