Carpe manana
![]() ![]() Join Date: Dec 2010
Need recommendation for adhesive to attach felt to A/C vent ball housing
I need to tighten up the A/C balls - can anyone recommend an adhesive to attach the felt? Couldn't find any recs on a forum search. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#2 | |
Re: Need recommendation for adhesive to attach felt to A/C vent ball housing
Jeff 1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt 1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior |
![]() Join Date: Jan 2001
^X2
3M Super Weatherstrip Adhesive is also available in black. It works well on weatherstrips, moldings, and gaskets. I'd bet it would work well on the felt, too. |
Carpe manana
Good deal guys -thanks! Where did you get the adhesive backed felt? I bought my fresh felt from a board vendor and it lacks the adhesive backing. Maybe backed felt is a better way to go...
![]() Join Date: Jul 2012
mine was'nt adhesive backed so I sprayed em with super 77 adhesive. Worked great....
#6 | |
that is some good stuff there. just tape up what you dont want coated and spray away IT WONT COME OFF if you dont want it too. any home depo,lowes,hardware store should have it. lil' pricey but you get pretty much in the can. another option is the small can of contact cement it come with a small brush in it and if used right it wont come off either but i would recomend the first too as they dont have a tendincy too soak through the weather strip stuff is really good(n probally less $) also they are all messy so be sure too tape up word of warning if you go this rout do not get the cheaper spray glue it will fall off in the heat of the summer(see my awesome vinyl headliner in my pontiac ![]()
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#7 | |
Carpe manana
Thanks again guys - all good suggestions. I have a can of Super 77 adhesive here that I'll try that first: it's leftover from my headliner install. It failed on that task. I had to go with the 3M weatherstrip adhesive in black to get the headliner attached to the roof.
Carpe manana
Just a follow-up. The Super 77 worked fine. I applied it to the felt then draped that into the housing. Wes (Classic Heartbeat) says he doesn't use adhesive and the felts stay put. May try that next time. Thanks again, Pete
![]() Join Date: Mar 2002
The ones from Classic parts don't come with adhesive, I cant imagine not having any on there but I've never tried it that way.
72low |
X2 on 3M 77 aerosol adhesive. 3M 99 aerosol is even stronger but you can't use it on Styrofoam but felt is OK. Both can be got a Home Depot.
Carpe manana
The Super 77 is holding up so far - was a bit messy getting the felt in place and trying to keep it off the free edge of the felt...follow-up pic that shows the repro felt is lighter in color than OEM
#13 |
I sure liked dealing with Classic Parts- good prices fast shipping and their quality is supreme.
72low |
#14 |
![]() Join Date: Oct 2009
Pete, I find it hard to believe your felts weren't already perfect. I could stare at that truck all day... Anyhoo - been a while since I bought these, but I could've sworn mine were adhesive backed. In fact, I think I bought them for an Impala, they had the same arrangement of felt+chrome ball. Pretty sure they were from either Impala Bob's or Year One - and they would fit these a/c vent holders as well, I'm almost certain. Anyway, glad they turned out good for you.
#15 | |
Carpe manana
