Active Member
![]() Join Date: Aug 2012
Interior Paint Formula
A friend who used to restore these trucks gave me the paint formula for the interior fawn color. This formula is for PPG lacquer paint.
Paint # DDL22151 Fawn Poly(also listed as Chantilly Beige Metallic) Mixing formula: Quantity 1 Pint Code------Color-------Cumulative------Parts DMA383---Red--------10.9------------10.9 DMA384---Yellow------40.9------------30.0 DMA349---Fine Alum---400.9-----------360.0 DMA310---Clear-------491.8-----------90.9 I copied this formula directly from the mixing label on an old can. My friend used this in a couple of '65 trucks he restored back in the mid '90s.He is a body man by trade and is very particular. We did some research and all of the mixing colors are still availabe through a source we have. Disclamer: I HAVE NOT used this formula myself. A color test panel should be made before actual painting of interior. |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Interior Paint Formula
Good info for the FAQ section. Thank's for sharing.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
I did a quick google search and found a couple pics of cars painted "Chantilly Beige Metallic". It's a mid '60s F*rd color. Giving some slack for different cameras/lighting/moniters, it's close to the original Fawn interior paint. Just not sure if I could live with a F*rd paint color being applied to my Chevy.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I dunno man-I understand you used some Nissan paint....lol
Yeah but Nissan isn't the main rival!
I'll admit I've had one or two of both. Actually the Nissan the spousal unit drove was a great car.
Active Member
I copied this formula information off of an actual paint can label. The application on the label reads: OEM: 48 MFG: GM 1962 TRK
DDL22151# Fawn Poly The Chantilly Beige MET color was on another label and read: Chantilly Beige MET, DDL22151# Both labels had the exact same mixing formulas. I assume Ford's Chantilly Beige was an exact match to the GM Fawn Poly truck color! It's my intention to offer this information as a help for other's in their attempt duplicate the original interior color in their trucks. Maybe Ford just knew a good thing when they saw it! |
So it was a '62 Chevy color that F*rd stole in '64... now we can use that info to poke fun at restored Mustang owners who really have a Chevy paint color!
Ha!
Great info Spudder, thanks for posting. |
#11 | |
![]() Quote:
I then asked for a printout of the color/formula in case I some day needed to match it--and had hit the lottery! Only then did I find out it was a BMW color. Gotta admit, tho', I do like the color and how it complemented the orange outside. Were I to redo the total paint process, even knowing the high price of the interior paint, I would just bite my lip and do it the same. Overall, what was that $200 extra when compared to the thousands that went into the total build? I think GM, along about 1960-1962, painted the exterior of some Impalas a 'fawn/beige' that would have approached the original pickup interior mighty close, whereby we could by-pass the F**d products. And I think my paint store could've mixed that GM fawn color in acrylic enamel and saved bunches of coins. They had no problem mixing the 1957 BelAire color I wanted on my '66 truck--GM called it Matador Red in '57; and it is absolutely NOT red, but orange. Went and looked at a '57 sport cpe. my painter had just sprayed that color and it was a perfect match for the orange I had mentally stored in my brain. BTW: Thanks for taking time to share the original formula. Many of us should benefit immensely from your generosity. Sam |
