Old 01-16-2013, 11:30 AM   #1
6twenty5
6twenty5's Avatar
Seat Belts...
Can anyone tell me if a 67-72 3 point seat belt can be mounted in a 64?
The wife is requesting a shoulder belt but I want to keep the bench.
1964 Chevrolet C-10 SWB
Fort Worth, TX
6twenty5 is offline   Reply With Quote
Old 01-16-2013, 11:40 AM   #2
64fleetside
Re: Seat Belts...
Just about any truck seat belts can be added, mine are from a 98 Chevy.
64fleetside is offline   Reply With Quote
Old 01-16-2013, 11:45 AM   #3
slepysal
slepysal's Avatar
Re: Seat Belts...
They sure can. Punch in seat belt in the search and you can find older post on how to do it. Not to hard to do
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 01-16-2013, 11:46 AM   #4
6twenty5
6twenty5's Avatar
Re: Seat Belts...
How did you mount the shoulder? I'd prefer not mount anything to the pillar but I don't know of another way.
Fort Worth, TX
Old 01-16-2013, 11:55 AM   #5
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Seat Belts...
Link
http://67-72chevytrucks.com/vboard/s...d.php?t=413117
Old 01-16-2013, 11:57 AM   #6
6twenty5
6twenty5's Avatar
Re: Seat Belts...
Thanks!
Fort Worth, TX
Old 01-16-2013, 04:38 PM   #7
ACK
ACK's Avatar
Re: Seat Belts...
This link shows step-by-step installation of shoulder belts in pre-66 trucks ...
http://www.bobshotrods.com/howto/3-p...chevy-pick-up/
I recently installed 2-point belts in my '64 and two things I recall that I want to share. If you locate the belts using factory specs, the hole you need to drill next to the driver and passenger door are located over a mount, so you'll have to drill through both the floor and the mount, which translates into longer grade 8 bolts, I think they were 4" long.
Second, be mindful of the gas line location under the truck, it's going to be really close to where you place the washer for the inner mounts.
A final thought, if you're installing a center belt, drill separate holes for them as well, don't share bolts.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 01-16-2013, 05:15 PM   #8
6twenty5
6twenty5's Avatar
Re: Seat Belts...
Great advice. I have relocated the fuel line with the aluminum tank in the rear so I can avoid that issue.
Fort Worth, TX
