Old 01-16-2013, 11:58 AM   #1
heyray
heyray's Avatar
Do These Fit???
Sorry to ask. I know there are many threads but so much info has me confused. Is anyone running these wheels? Thoughts would be appreciated.
72 Blazer 2wd
http://www.summitracing.com/parts/mbw-23207
72 Blazer 4wd
72 Blazer 2wd
69 Blazer 4wd
easy to take apart hard to finish.
Ray of all trades master of none.
heyray is offline   Reply With Quote
Old 01-16-2013, 12:13 PM   #2
fatboy43
fatboy43's Avatar
Re: Do These Fit???
i do belive that they will. i prefer a 4 inch backspace myself.
fatboy43 is offline   Reply With Quote
Old 01-16-2013, 12:41 PM   #3
c10Dream'n
c10Dream'n's Avatar
Re: Do These Fit???
72 Blazer 2wd
I like the look of those. What size tire are you going to run?
c10Dream'n is offline   Reply With Quote
Old 01-16-2013, 01:26 PM   #4
Pro Performance
Pro Performance's Avatar
Re: Do These Fit???
That backspace will be Ok up front on a static dropped truck. For the rear, they will be Ok also, but might want to run a small spacer to push them out a bit, but it is all personal preference.
- Travis
Pro Performance is offline   Reply With Quote
Old 01-16-2013, 01:56 PM   #5
OrangeCrush1970
OrangeCrush1970's Avatar
Re: Do These Fit???
This is another time that makes me with I had 5 lug axles....I like those wheels, they will look awesome. Backspacing should be your only concern with your drop, etc as stated above. Take some measurements to be sure, I think summit has a pretty good info section on that.
Rottenwood Garage
1970...71...72 C1500 aka Orange aka Sideshow Bob
540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600
2 Tons of Fun
OrangeCrush1970 is offline   Reply With Quote
Old 01-16-2013, 09:48 PM   #6
heyray
heyray's Avatar
Re: Do These Fit???
Thanks Guys Im dropped 3.5 up front and 4.5 in the rear but I need to drop 1 more inch in the rear. Big block 700r may have the front a bit lower than expected.
I havent come up with a tire size yet not a big fan of really low pro. thinking 55 series??
72 Blazer 4wd
72 Blazer 2wd
69 Blazer 4wd
Old 01-16-2013, 09:51 PM   #7
heyray
heyray's Avatar
Re: Do These Fit???
- Travis
What backspace do you recommend? Can you get these wheels? I prefer to buy from you.
72 Blazer 4wd
72 Blazer 2wd
69 Blazer 4wd
