Old 01-16-2013, 12:45 PM   #1
c10Dream'n
c10Dream'n's Avatar
C-notch ?????????
Just wondering if an LMC c-notch has the durability based on the price of $140 vs. one from PB for $250. Thoughts......
c10Dream'n is offline   Reply With Quote
Old 01-16-2013, 01:13 PM   #2
Pro Performance
Pro Performance's Avatar
Re: C-notch ?????????
Both will work in most cases, but the Porterbuilt is definitely a heavier duty c-notch. Especially being you are cutting out a section of your frame, the Porterbuilt better re-inforces that area in my opinion.
Pro Performance is offline   Reply With Quote
Old 01-16-2013, 01:19 PM   #3
c10Dream'n
c10Dream'n's Avatar
The porterbuilt was my first choice until I saw the one from LMC. Can you PM me a quote if different from the price I stated? Thanks.
Old 01-16-2013, 01:21 PM   #4
c10Dream'n
c10Dream'n's Avatar
Another question may be, do people use it primarily as a bolt-on, or do they weld in place for extra strengthening?
Old 01-16-2013, 01:21 PM   #5
Pro Performance
PM Sent
Old 01-16-2013, 01:23 PM   #6
Pro Performance
Most people will bolt-in, which is plenty strong. I have seen it welded as well, if you want a little cleaner of a look without the bolts showing. I personally like the look of the bolts.
Old 01-16-2013, 01:33 PM   #7
shawno72
C/10 junkie
shawno72's Avatar
X2 on the bolt look. Especially grade 8 hardware with a black or dark color notch.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-16-2013, 01:42 PM   #8
c10Dream'n
c10Dream'n's Avatar
I'm liking the bolt look myself.
If the frame is coated with POR15, should I do the same to the notch or just spray it black?
Old 01-16-2013, 02:19 PM   #9
CC69Rat
CC69Rat's Avatar
PB notch in my GMC. Top notch stuff man. It has 17 grade 8 bolts in it. I honestly feel like its stronger with the notch than it ever was without it. Check out my build and there are a bunch of pics. The main thing is you gotta take your time. Its much easier with the bed off too. I dont regret it for a minute.
I have an extra upper shock bar Ill sell if you need it. Also highly suggested addition. It helps a lot with shock travel and efficiency.
Travis, I need some PB stuff brother.. can I get it through you? PM? Sorry for the minor hijack.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 01-16-2013, 02:25 PM   #10
Pro Performance
Yep, I can get it for you, no worries. I'll send you a PM and can go from there with what you need.
- Travis
Old 01-16-2013, 06:05 PM   #11
AusTx68
AusTx68's Avatar
Can the PB c-notch be installed without removing the bed?
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 01-16-2013, 06:08 PM   #12
Pro Performance
Yes, but will be a little more difficult to drill the holes that go through the top of the frame rail.
Old 01-16-2013, 06:12 PM   #13
CC69Rat
CC69Rat's Avatar
Titanium step bits make things a whooole lot easier too.
Chad
