Old 01-16-2013, 12:56 PM   #1
cjb70chevy
rearend gears
i got 70 chevy with 12 bolt, tires are 235/55/15. stock gears in it are 2.73's. i'm going to be putting in either 3.73 or 4.10's but i don't know. question is how can i high will the rpms be at cruising down the highway. i want the higher gear but i don't want the rpm's to high if i want to cruise down the highway
cjb70chevy is offline   Reply With Quote
Old 01-16-2013, 01:09 PM   #2
cdowns
cdowns's Avatar
Re: rearend gears
273 you have high gears now// a larger number like 373 411 etc are lower gears
Old 01-16-2013, 01:17 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: rearend gears
Yup... you want lower gears (numerically higher). 4.10's re gonna get you around 3,500 RPM's at highway speeds with a non-overdrive tranny.
I have a TH350 and 3.73's in my rig and run just under 3,000 RPM's at highway speed.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-16-2013, 01:21 PM   #4
~Whitey~
~Whitey~'s Avatar
Re: rearend gears
This is 4:10 gears, 350 motor, turbo350 transmission. 2wd shortbed. PS... that's with 275/60/15 tires.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 01-16-2013, 01:34 PM   #5
69GWC
Re: rearend gears
Truck would scoot around pretty good on 3:73 and not turn a lot of rpms, but if you had a overdrive the 4:10s would be nicer to have.
69GWC is offline   Reply With Quote
Old 01-16-2013, 01:39 PM   #6
70CHEVYBB
70CHEVYBB's Avatar
Re: rearend gears
3:73 should be around 2700 rpm and 4:10 will be around 3000 rpm at 55
70CHEVYBB is offline   Reply With Quote
Old 01-16-2013, 02:28 PM   #7
cjb70chevy
Re: rearend gears
thanks for the advice, much appreciated...
Old 01-16-2013, 02:52 PM   #8
1972SUPERSB
1972SUPERSB's Avatar
Re: rearend gears
Here is mine with 3.73 gears with 255/70/15 tires and TH350 trans.
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-16-2013, 04:02 PM   #9
SS Tim
SS Tim's Avatar
Re: rearend gears
Since 2.73 gears were not stock in '70 are you sure that is what you have? '70 Stock 12 bolt gears were generally 3.73 or 3.07 with a 4.11 option. Without any driveline info it is kind of difficult to say what is best for you. Here is a basic calculator that should help.
http://www.chevellestuff.com/tools/rpm_calculator.htm
SS Tim is offline   Reply With Quote
Old 01-16-2013, 04:55 PM   #10
robnolimit
robnolimit's Avatar
Re: rearend gears
get an OD and use 4.10's. best of both worlds.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 01-16-2013, 07:41 PM   #11
cjb70chevy
Re: rearend gears
it has 2.73's in it. i have serviced rearend 2 since i've had it and checked each time. i am the 4th owner, found 2 previous owners and no one has said they changed it. the trucks an all origional 70 chevy 402 bbc th400 trans a/c cab. its possible the 1st owner changed it but idk. the first owner had it for about 17 years.
Old 01-16-2013, 08:25 PM   #12
SS Tim
SS Tim's Avatar
Re: rearend gears
Interesting, So it tooth counts and divides to a 2.73:1 ratio? Did you check the axle codes? Is it on the SPID as a special ratio? Is there a build sheet. Everything that comes to hand is showing a 3.07 to be the stock/only gear. Have to go and dig out my 70 engineering specs book tonight and see what that has to say.
Seems like a lot of work for about a 250 RPM drop (from 3.07s) on the freeway, but if you are running fast, a lot, it could be desirable.
http://67-72chevytrucks.com/vboard/s...d.php?t=561137
Old 01-16-2013, 08:57 PM   #13
cjb70chevy
Re: rearend gears
the code on axle is scratched down far enough i cant make it out. everything i've lookd up no truck had 2.73's. i just assumed that because it has a big block with a 3 speed automatic they would of wanted the lower gear for highway driving. the truck index in the glovebox doesn't have anything on the rearend gears. i really appreciate the help but no need to go to to much trouble as i would like to run a different set of gears.
Old 01-16-2013, 09:18 PM   #14
SS Tim
SS Tim's Avatar
Re: rearend gears
Well then a set of 3.54 or 3.73 gears would be about the best compromise with your stock trans.. But a Gear Vendors O/D and 4.11s will put the grin factor into your truck. You end up with six speeds and the ability to past a gas station or two along the way.
Old 01-16-2013, 11:27 PM   #15
oldspowered67C10
Re: rearend gears
Use this page to expiriment with:
http://vexer.com/automotive-tools/speed-rpm-calculator
I have 3.08 with 295/35-20 and a th400, 3000 rpm@80mph.
oldspowered67C10 is offline   Reply With Quote
Old 01-16-2013, 11:35 PM   #16
70blackfish
Re: rearend gears
if you use your truck to haul a lot or tow a lot. use 4.11 if not go with 3.73
your tires are not very tall..
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-17-2013, 01:14 AM   #17
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: rearend gears
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-18-2013, 11:28 AM   #18
cjb70chevy
Re: rearend gears
only thing i pull with it is the jetski or a buddies boat, and the haulin my buddies boat the fatty really wasn't grunting to hard. what does an overdrive usually run?
Old 01-18-2013, 11:37 AM   #19
cjb70chevy
Re: rearend gears
and the th400 is heading to the trans shop to get built/ an with a shift kit
Old 01-18-2013, 03:43 PM   #20
Fitz
Re: rearend gears
Go here:
http://www.grimmjeeper.com/gears.html
Enter your trans type OD/no OD, tire size, rear gears and MPH. Use 1 for high range, low range and 3rd range (your high range is 1:1, you don't have the others) It will calculate RPM for you or, put in RPM and it will tell you resulting speed in every gear. You will likely see you do not want 4.10's unless you add an OD. 3600 revs for 65 mph is going to be REALLY loud and with the current occupant at 1600 Pennsylvania Ave. gas isn't gonna get cheaper......
Fitz is offline   Reply With Quote
Old 01-18-2013, 05:00 PM   #21
cjb70chevy
Re: rearend gears
i agree on the gas not getting any cheaper thats why i drive my saturn that gets 37mpg. but for me atleast. my truck is the one thing i do to have fun/helps me forget harsh reality's of life for just a little while. i honestly don't care about if its good on gas, not the way i'm building it. that and its got a factory big block lol. thanks for the link tho
Old 01-18-2013, 05:08 PM   #22
hyatt
Re: rearend gears
Not a truck but I have a bigblock chevelle with a 400 turbo and 273s I think it is the perfect combo The bigblock has plenty of low end torque an 67-70 mph cruzing is effortless Engine runs cooler and uses less gas and still smokes tires at redlight If it were my truck I wouldnt change a thing
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 01-18-2013, 09:16 PM   #23
Ends
Re: rearend gears
most rear end specialists i have talked to tell me that if your tire is 30" from the ground to the top of the tire or higher that a 4:10 gear ratio will act much more like a 3:73.
LAYDIIREST member
1970 C10 stepside full tube Chassis, supercharged 454 and much more, 95 motor and trans swap, pro street SLAMMED!
1951 Fleetline custom chopped, channeled, narrowed.
Ends is offline   Reply With Quote
Old 01-18-2013, 09:33 PM   #24
cjb70chevy
Re: rearend gears
i got a set of 235/55/15's now but am planning on putting 20's all the way around, and i'm always looking to the future, thats y i'm wanting to put a bigger gear. just want to do it once.
