Old 06-10-2003, 11:52 AM   #1
ScottH
ScottH's Avatar
Front suspenion swap question
Considering buying a 68 k20 and would like to install front discs. I can get a donor 80 C20 front end. Can anyone tell me if I can just swap the spindles and brakes from the C20?
Thanks.
ScottH is offline   Reply With Quote
Old 06-10-2003, 11:54 AM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
If you're referring to a 4wd 68 and a 2wd 80, it's a no go. The spindles are not interchangeable between 2wd and 4wd regardless of year
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-10-2003, 11:58 AM   #3
ScottH
ScottH's Avatar
Thanks Jeff....btw would it work if they were both K20s?
Old 06-10-2003, 12:01 PM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
I doubt is as the 68 is a closed knuckle dana44 FE. You could swap the entire front axle however, though I'm not sure of the implications there.
Old 06-10-2003, 02:38 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Just find an axle from a 71 or newer truck it will bolt right in. Of course you'll need to replace your brake lines and master cylinder/booster as appropriate.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-10-2003, 09:21 PM   #6
ScottH
ScottH's Avatar
Thanks to all!
