Old 01-16-2013, 04:53 PM   #1
1bad84silverado
What is the best method to drop my truck?
First off I'd like to introduce myself I'm from Kyle,tx and just acquired my brothers 1984 Silverado so I'm new to the truck seen. I like to lower my truck probably a 4/6 drop with some 20inch coys or torque thrust. I just don't know what 84 with a 4/6 drop would look like with 20's so if someone has pics with a this setupor if there is any complications with running that big of a rim or if my long tube hedmans will hit speed bums with 20's being dropped that low. Also what is the best and cheapest method with a good ride to do this? I will see if I can post up some pics of what it currently looks like. Thanks.
1bad84silverado is offline   Reply With Quote
Old 01-16-2013, 05:03 PM   #2
LEEVON
Moderator
LEEVON's Avatar
Re: What is the best method to drop my truck?
Welcome and nice truck! There is a huge long thread on here with lowered 73-87 trucks, check it out. 4/6 is the right drop for these I think.
Not sure about your headers. Wheels are fine. 8.5" front and 9.5-10" rears.
As for the drop cheap and best are relative. I'm a tight a** and I like quality parts and a nice ride but I can't afford to throw a $7k Ridetech kit at my trucks. Here are the parts I have collected for my '87, which will be getting dropped soon. This isn't much different than any other truck with IFS that I've done, with exception of the new ones.
-Flip kit $40 (classifieds here)
-rear shock relocators $60
-2.5" spindles (McGaughys) $250
-cut 1 coil
-1.25" sway bar (optional)
So $350 plus an alignment. I have the sway bar laying around. On the simple bracket flip, you will re-use your u-bolts provided they aren't too rusty and drill a hole 1" away from the retainer plate's existing u-bolt pin hole to locate the axle correctly.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-16-2013, 05:06 PM   #3
DREAMER1
DREAMER1's Avatar
There are a variety of "cheap" drops. But the best way to do it is to do it "right". Drop spindles in the front with a flip kit in the rear for starters. Here's mine with 20s
DREAMER1 is offline   Reply With Quote
Old 01-16-2013, 05:07 PM   #4
LEEVON
Moderator
LEEVON's Avatar
Here is enough reading for a couple of nights:
http://67-72chevytrucks.com/vboard/s...d.php?t=204533
http://67-72chevytrucks.com/vboard/s...d.php?t=492874
When your on the 73-87 page, go to the lower left at display options and pull the tab down for "beginning". Then sort at the top by replies or views. You will have all of the most popular threads since the beginning at your disposal.
Old 01-16-2013, 05:46 PM   #5
meatwagon83
meatwagon83's Avatar
just chop the springs in half! you aint cool unless it drags the speed bumps dawg!!!
meatwagon83 is offline   Reply With Quote
Old 01-16-2013, 05:49 PM   #6
kalbert
Sweet color combo, I like it.
Curious, what wheel/tire combo is on it now? Looks like factory rally's with BFG All Terrain's, what size?
kalbert is offline   Reply With Quote
Old 01-16-2013, 05:54 PM   #7
cory d
cory d's Avatar
hedman long tubes hang pretty low, i have smashed mine pretty flat. then they crack
cory d is offline   Reply With Quote
Old 01-16-2013, 06:29 PM   #8
1bad84silverado
factory rally's with bfg all terrain 31x10.5r15
Old 01-16-2013, 07:37 PM   #9
1bad84silverado
i really like the stance of these though i have no clue what they have done to them. Any help would be great.
Old 01-16-2013, 08:05 PM   #10
zook
zook's Avatar
welcome to the forum and congrads on your new ride. I think a lot depends on how much you want to spend...it's unlimited. Good luck. I have drop springs/spindles and flip kit on mine and will be putting on some staggered 17's in the next couple days...hoping for some warm weather.
zook is offline   Reply With Quote
Old 01-16-2013, 08:20 PM   #11
bbbc10
Diggin The SquareLife
first truck is 5/5 drop an the second is 5/7....i wouldnt cut springs.....dnr half ass it th first time....mine is lowered 5/6 but i dnt have 20s
bbbc10 is offline   Reply With Quote
Old 01-16-2013, 08:29 PM   #12
bbbc10
white truck is 4.5/6 drop wth 20s
blue truck is 6/8 drop with 20s
red truck is 5/7 drop with 20s
Old 01-16-2013, 08:47 PM   #13
zook
zook's Avatar
I like them all they all look good and low. more into lower than lifted. big blocks are a plus too! just my 2 cents and worth nothin.
Old 01-16-2013, 09:05 PM   #14
1bad84silverado
Thanks fellas for all the help. I'm liking the forum already everyone seems very helpful. I think I will start with a 4/6 drop and go from there. Now what rims coys chrome or gray. Remember pics of my truck are at The utop.
Old 01-16-2013, 10:15 PM   #15
LEEVON
Moderator
LEEVON's Avatar
Cutting one coil of less is far from half-assed. I've had many drop springs, nothing wrong with them they're just not always necessary. 1bad84silverado...you did say cheap and best, my advice is solid. If you don't like the ride after one coil cut, yank it and add drop springs. Ride quality issues are far more likely to come from poor shock angle, crappy drop shocks, un-trimmed bumpstops, pinion angle, and a bunch of other things. It's a "big picture" thing.
Old 01-16-2013, 11:04 PM   #16
J Knight
J Knight's Avatar
-cut 1 coil
Ive dropped many trucks myself and would agree with Leevon 100%, this is how to do it right without buying a bunch of unecesary parts.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 01-17-2013, 12:15 AM   #17
KrazyRay
KrazyRay's Avatar
I like your combo of wheels, drop, and paint. Not to hijack, but what paint did you use?
KrazyRay is offline   Reply With Quote
Old 01-17-2013, 03:24 AM   #18
81Scottsdale520
81Scottsdale520's Avatar
i used a flip kit in the back i havent got to cut the springs in the front because the transmission ended up dying on me so until i fix it its gonna stay like this for awhile.
~When In Doubt Go Lower~
81Scottsdale520 is offline   Reply With Quote
Old 01-17-2013, 03:28 AM   #19
1bad84silverado
Is this a good kit to go with? Also what could I do to drop it that extra 1/2inch in the rear? Here is the link with the kit I was thinking about getting.http://www.ebay.com/itm/1973-1974-19...500fb2&vxp=mtr
Old 01-17-2013, 03:32 AM   #20
1bad84silverado
I didn't know you could do this just with a flip in the rear and cutting springs. How is ride quality when you go this route? Anybody? Aproximately when you cut one whole coil how many inches does the front drop?
Old 01-17-2013, 03:34 AM   #21
cory d
cory d's Avatar
i flipped, with drop shackles and 2 cut coil. stock coils are too soft. my buddy has HD coils with 2 cut adn it rides great
Old 01-17-2013, 03:35 AM   #22
1bad84silverado
What is the bolt pattern for the wheels? Like I said I'm new to trucks so I have not a clue.
Old 01-17-2013, 03:42 AM   #23
1bad84silverado
I think I may just save my pennies and go with something like this if this is a good kit.
Old 01-17-2013, 03:42 AM   #24
cory d
cory d's Avatar
5x5" or 5x127mm care when buying wheels on craigslist, people often say 5x5 then say its off an s10 or camaro (5x4 3/4) or frod/dodge 5 lug (5x5.5)
Old 01-17-2013, 09:31 AM   #25
SCOTI
SCOTI's Avatar
Check in here & see if there's a board supporting vendor that can help you before doing an e-bay purchase w/minimal or no customer service if you have issues....
http://www.67-72chevytrucks.com/vboa...play.php?f=210
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
