Has anyone actually used a c60 cab?
I've done a lot of reading and can't find anyone that has actually used a c60 cab on a c10. We have 3 of them around the farm, and they have descent cabs on them. None are LCF trucks. I'm just curious what the difference actually is besides the floors?
Jordon Vermilion, Alberta, Canada 56 lwb stepside 66 lwb BBW 66 swb parts truck |
Re: Has anyone actually used a c60 cab?
as long as it not a LCF cab it should be close. I seen one on a GMC and they even kept the running boards, but it looked funny with the smaller front fenders and those runningboards.
I have also seen one I was told was a big truck cab, not know that at first I really could not tell. floor and steering colunm are two things i can think of and I'll bet cab mounts may differ. Now if you had a good LCF cab....I could use one of those.
Jolly ~ The 6066 GMC Guy Try the 6066 GMC Guy Facebook Page Jolly's Truck & Car Show Page! |
I sold the one I had to a fella from Ohio-the mounting bolts are in a different location, and the trans hump is flat, but a half-ton hump replaced it no problem. Firewall is slightly different where the column/MC mounts up. Nothing has to change that is as hard to do as repairing rust-out. The C60 cab I had was totally rust free-was a soybean truck used once a year and kept under a barn. Firetrucks are also good candidates.
1961 crewcab
I have one loose on a c/10, that someone had already switched over years ago, they bolted/screwed in a high hump, and removed the front cross brace.
I also have a c/60 that had the cab replaced with a c/10 cab, they cut out the high hump with a torch, (this was a weld in hump cab) and installed the flat panel, the cross brace is missing, and the lower inner fender bolts are missing too., it is a 66 cab and the frame uses the wide 60-62 front bolt mounts.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
There's a few differences but nothing you can't handle. I have a 63 C60 cab mounted on a 64 4WD frame.
UCA63
I've got a high hump and surround if you're interested..just pay the shipping or pick up and its yours
Unfortunately I don't have the inner fender mounts ..LOL ask Aerotruk why? T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) Last edited by 63sbssbbw; 01-17-2013 at 06:00 PM. Reason: sp. |
What is much shorter and at different elevation for C10, Alex.
Do I win? Trent came to the rescue for the inner fender mounts for my 4WD. 8.155 Bracket Assy. ![]() |
UCA63
Funny how it says 65-66 (typical) when the 64-5-6's were welded on.!
That is a '63...Unless you actually know this(lol like we do)..that illlustration could really confuse.! T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
I'm hoping I can slip home today and take a look at the 64 we have sitting on some land we own. I want to see how bad it is before i get too crazy about the idea
