70 stanard options
I'm looking at a 70 lwb , says comes with orignal 4 speed tranny. Was this an option?
And how difficult is it to add power steering? Posted via Mobile Device
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
Re: 70 stanard options
A C30 would have a four speed as standard. C10-20 K10-20 had three speeds as standard. I'm sure I could tell you more if we knew what you were asking about.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Is the steering shaft shorter on a powered gear box?
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
![]() Join Date: Sep 2011
I put PS on my 71 C20. It wasn't difficult at all. I got the steering box, Pittman arm, pump and pulley set from a donor truck, so it all fit just fine. The steering shaft telescoped to adjust, so that wasn't a problem either. I am definitely happier with the power steering.
1971 C20 "Shreck" 1980 C30 dump bed "Ratchett" |
Thank you for your responses
I'm looking at a 70 lab second owner, and its a 4 speed with a 283. I didn't know if this was a combo that would have came from the factory. Again guys thanks for your time
A 70 C10 (it is a C10??) LWB would have come stock with a 3 speed column shift trans.. The engine if a CE10... would have been 307 2 bbl. V-8, a CS10... would have been a 250 I-6 as base engines. Remember '70 was the last year of front drum brakes and 4x2 six lug wheels. This link might help some too.
http://www.oldcarbrochures.com/stati.../dirindex.html
Was a 283 an option in 1970? Like the ones with the oil fill at the front of the intake instead of in the valve cover? Not that it is too big a deal if you aren't worried about being 100% factory correct. I think a little 283 would be fun.
No the 283 ended in '68. Many people have them and they are a little better on fuel than a 292 out on the road. You can dress a 283 to look like a later 307/350 just don't expect a MPG increase.
my CST C10 - 70 came with 350 3 speed, and Power steering
The 350 and the P/S are both options and will be listed on the SPID.
#11 | |
"Standard" and "options"are mutually exclusive. "Standard"is what you get with out specifying "options".and the options replace the original equipment.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#13 |
Service Parts Identification Plate, It is found on the inside of the glovebox door often worn, faded, peeled, painted over, notated or kid scribbled on.
#14 |
ah thanks
#15 |
I am a Referee of life.
Or swapped from a different truck.Check VIN against the one in the truck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
