Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-17-2013, 04:19 AM   #1
SoCalSlaughter
SoCalSlaughter's Avatar
ECMB problems! No fuel
At a loss at this point. Truck is 90' Suburban V2500 4X4 5.7 th400. A few days ago I was running errands, truck kept flashing engine light and would stumble then keep on driving fine. The night before i was driving to the hardware store and engine light came on, code 42. Went away after starting truck up again. Anyways, got home and went to back into my driveway and once I put the truck into reverse it shut off. It cranks but wont start. Turn key to ON and all lights come on but fuel pump does not prime. Took fuel filter off and cranked and no fuel. Replaced pump and same result. Followed wires from pump all the way up to the firewall where they meet into the fuse block. tested ignition module and its good. (Tested 4 times and checked with a spare) Truck cranks but no fuel. Checked fuel pump relay with 3 others, same result. Checked all wires on firewall to fuse block. Nothing it grounding out. And at one point when I was trying to turn to key to on, the ECMB fuse would blow. Did this about 4 times until it was able to hold and keep engine light on. Tested ECM from my 89 Suburban and same result. Dash lights come on, hear the fuel pump relay click and still no fuel. Checked voltage on fuel pump and getting about 8.45 volts with key on. Replaced pick up coil, same result. Im out of ideas....
SoCalSlaughter is offline   Reply With Quote
ecmb, fuel pump, no start
