Project Heaven in my 67!!!
where to wire in my electric choke
Where have yall been obtaining the 12V feed for your electric chokes when the key is on? I have an electric choke carb and would like for the choke to be operational.
Re: where to wire in my electric choke
I have an eddy 1406 with an electric choke, but I'm honestly not sure where the 12v comes from. I'll check over lunch for you.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Thats the same carb I am working with. Had to take apart and clean and rebuild due to a long sit and now I figured I might as well make it work like it is supposed to. I appreciate the help.
no problem. I had to do the same thing. it was the first carb I've taken apart and it wasn't as bad as I thought it would be. I realize it isn't a full rebuild, but all the major gaskets and cleaning all that crap out solved quite a few weird problems for me.
Mine, for the first time in three years, is going to move under its own power today. But, I sure would like to get that choke working!
Well I certainly can't stand in the way of that! I'll post up around 11:30, noon at the latest. IIRC the P.O. has a small gauge wire running through a grommet in the firewall, but I have no idea if the hole is supposed to be there or not, or what it's wired to under the dash..
My guess would be the positive ignition wire. He probably just spliced it off under the dash. You could also use the fused side of the ballast resistor. Any spare spots on your fuse block? You could check them to see if they are switched 12v.
Not sure if there is any open space. I was actually thinking that doesnt the starter have a terminal on it that is only hot when the truck is running? If so could I wire it down to the starter?
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
No, the starter doesn't have a hot wire only when running. The fuse block has a couple of unfused ign terminals that should fulfill your need
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Thanks, for some reason I was thinking there was a start terminal which receives a signal from the key, and then I was thinking that the other terminal was a run terminal which was 12v while it was running... LOL no idea where that came from!!!
Older Ford solenoids had a ign terminal, you my friend are suffering from Ford poisoning. LOL
#13 |
The Older Generation
I would guess you would use the "IGN UNFUSED" terminal on the fuse block. It is hot whenever the key is on. LockDoc
#14 |
#15 | |
Should be room for it with the 3 washer hoses or the oil pressure line. LockDoc
#16 |
I agree with Lockdoc, should be able to squeeze thru at one of 'em fairly easy
#17 |
If you have HEI Ignition, use the old coil wire.
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
#18 |
Only problem with using the old coil wire is it is a resistor wire and isn't 12 volts. It's more like 8.5 volts and the choke would tend to heat up way slower.
#19 |
![]() Join Date: Dec 2012
I don't know if this will help in your situation. To add mine and HEI what I did was....
1. Turn on the ignition. 2. Poke in the connector box under the hood with a pointy test light in each of the holes without a connector. 3. I found one that wasn't being used that light up the light. 4.Turned the key off and made sure the light went out. Test that one again with the key on to make sure it went on again. (The old measure twice cut once.) 5.Removed the bolt from the center of the connector under the hood. 6.Went to Autozone and got a connector that looked like the others in the engine compartment connector. I had to buy a pack of 5. 7. Crimped a wire in and put it in the connector and connected to the fuse box again, and VOILE` I had 12 Volts to power my HEI and choke.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#20 |
I used the old coil wire on My CJ with Edelbrock carb, heats up the choke just fine.
Ron
#21 |
I don't know how the CJs are wired Ford and Chrysler used 12v to their coils with either external resistors or coil with an internal resistor. GM used a resistor wire to cut down the voltage. 8.5v will heat the choke but at a slower rate. Just my 2 cents for what it's worth nowadays LOL
#22 |
laying low
![]() Join Date: Mar 2001
Do put an inline fuse on it though. It's good insurance.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#23 |
#24 |
Just found this
http://67-72chevytrucks.com/vboard/s...d.php?t=445794 Sorry about not getting pics up yesterday. It's been busy around here. I should have them up tonight around 4 or so, but I'm not sure how much help they'll be.
#25 |
double
