Swapping parts from 76 to 68 c10
Guys - Can you tell me if the following parts off a 76 c10 will fit directly to my 68 c10 or will it take a little altering?
Master cylinder / booster Complete front suspension AC/heater set up steering column Thanks Jeff |
Re: Swapping parts from 76 to 68 c10
The whole front engine crossmember will fit plus the booster and master cyl.,gives you front disc brakes.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
![]() Join Date: Aug 2008
I saw a thread somewhere on here where someone installed a 73-87 evaporator into a 67-72 box and used all of the 73-87 lines as well in order to go to the modern cycling system instead of the poa valve...
Posted via Mobile Device |
Thanks for the replies. Helps alot. I am looking at buying a running 76 to convert to disc brakes, ralleys, ac, 350, etc.
The crossmember WILL fit, but it will raise the engine stands about 1/2 inch, meaning you will need to make a spacer for the top side of the engine mounts. To avoid this, just move the control arms and keep your crossmember.
No problems here on the cross member swap and this is the first I heard of a spacer needed for mounts.I have been running this set up for years hmmmm would it be differant tower/motor mount option ??
Ive done 2 and when I did my daughters 66 GMC the mounts did not fit exact. I was told that it had to do with the height of the frame sidewall. The other truck is a 84 and I did not measure it but was told that the 84 frame is taller than the 66. The rest bolted under perfect but the plates had to be modded.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
I used a 74 crossmember and a 76 on another maybe they changed when they went to the metric sh#$ I mean dimentions
