Radiator - Where to buy?
My 70 C10 is in need of a new radiator. The tanks have a couple pin holes each and I think there maybe a leak between the the core and one of the tanks. I checked oreillys and advanced auto parts and they both told me there are none in the warehouse and they don't know when they will be back in stock. Motor is a 307 w/3ott and no a/c.
Posted via Mobile Device |
Re: Radiator - Where to buy?
Do you have CarQuest in your area? I bought one for my truck there. I'm sure LMC, Classic Parts, etc. can help you out as well.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
![]() Join Date: May 2011
ugh. Yes I thing Advance is discontinuing them. Could try the usual sources, GMC Pauls, Brothers Classic Parts. Use "Stovebolt" at classic parts right now for 10% off
#4 | |
#6 | |
![]() ![]() Join Date: Sep 2008
Orielly website says they can have you one in 24 hrs, $184.99.
#8 | |
Old member
![]() Quote:
106 Wolf Creek School Road Pickens, SC 29671 (864) 878-6052 Talk to Gordon. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Replacement radiators for these trucks at DIY auto parts stores in my neck of the woods are all brass and about $200. The replacement rad from same store for my 92 K1500 was aluminum and plastic. Radiator repair shops around here are quickly dying off, in part to our nanny states regulations and due to non repairable aluminum and plastic rads in most cars post mid 80s.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#10 | |
#11 | |
Old member
He didn't rod it out but fixed the upper water neck that was leaking and cleaned & flushed the inside out. Repainted it black.
#13 |
#14 |
When I looked mine up at O'Reilly's it said it was aluminum and plastic but when it came in it was all metal. I ordered a 4 core for a 72.
-Scott- |
#15 |
around here we have a place 1 800 radiator i see ads all the time and know a few guys that have gotten good radiators at cheap prices overnight
#16 | |
Old member
![]() Quote:
#17 |
Have you considered a custom aluminum radiator? I have a Fluidyne rad in my truck. The only thing is on my radiator there isn't a built in trans cooler so you would have to run an external trans cooler but direct fit aluminum radiators can be anywhere from 1-200 bucks and IMO look cooler then the stock ones. Just an option to keep in mind
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 1972 Chevy SWB Highlander OLIVE Build thread coming |
#18 |
If it helps any, look up radiators for a '77 malibu. I went to pepboys for mine. It's the same dimensions ( 28 1/4" x 17") if you are ok with a 2 core, and that it's plastic and aluminum. It was only a 100 bucks. Fit right in there. Only problem was the bottom diameter was 1.5" and my hose was 1.75" I inserted a piece of the upper hose in the bottom hose to fill up the gap. Just throwing this out there.
#19 |
If you were closer I have one for a 72 Chevelle which is the same as our trucks .
#20 |
Registered Cruiser
I have an O'reilly's 4 core radiator. It started leaking after ten years. They replaced it on the lifetime warranty. No Questions asked. I'll never have to buy another one.
I intend to live forever. So far, so good. |
