Old 06-10-2003, 04:46 PM   #1
bpmcgee
bpmcgee's Avatar
Question re: alternator swap
Hi,
Will I have a problem with my ammeter if I switch from an external to an internally regulated alternator?
I can't imagine why, but I'm trying to explain a problem I had in the dash earlier. I don't know if it was a cause or a symptom, but one of the traces on the instrument circuit board going to the ammeter was melted.
Brian
bpmcgee is offline   Reply With Quote
Old 06-10-2003, 04:55 PM   #2
sam's 72
No, you won't have a problem. I did the swap on mine and it works good. I didn't want that many amps comming into my cab with out being protected, so when you go to run the wire to the amp gage put a inline fuse in place, so if it shorts out it will blow the fuse.
Sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
Old 06-10-2003, 06:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
There should be 2 fuses protecting the guage as is out of the factory.
Old 06-11-2003, 10:19 AM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
I recently read that if you go with a higher output alternator, over 60 amps, you will damage the stock ammeter gauge and probably burn the gauge wires. I'm gonna change mine to a voltmeter.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
