01-18-2013, 12:27 AM | #1 |
HID help
http://www.amazon.com/gp/product/B00802G20C/ref=no...i found this hid kit, the thing is what housing do i need and where do i get it? i hear about this h4 and h7 housing which i dont really understand i need some help!!!!!
~When In Doubt Go Lower~ |
01-18-2013, 01:33 AM | #2 |
Re: HID help
You will need a set of headlight conversion lenses. Google or check Ebay and you will find em. A word of advice though, avoid any marked "diamond cut" or "euro" and all the fake projector housings. Look for "e code" housings as that will give you the best and least scattered light output short of doing a proper projector retrofit.
Also id recommend hid kits from ddmtuning.com, good prices and a solid product. Posted via Mobile Device |
01-18-2013, 04:22 AM | #3 |
Re: HID help
That's spendy.
Go to ddm tuning and get the kits with warranties. Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-18-2013, 05:44 AM | #4 |
Diggin The SquareLife
Re: HID help
i payd more than that for my hids and relay kit...here are the headlights i used..they are h4 housing headlights so u will need hids that are h4...btw i did 10k hids.... Pilot WI-HL6A 4656 Head Lamp Conversion Kit :...
01-18-2013, 05:46 AM | #5 |
Re: HID help
also u will have to cut the hid harness in half then slide the wires threw the rubber boot that goes on the back of the headlight and then rewire the hid harness bacck together
01-18-2013, 01:16 PM | #6 |
Re: HID help
Them things just throwing light everywhere!
Get hella e code lights and a $30 hid kit with the good digital ballasts. I've had mine for a year and no problems and still ha it's lifetime warranty Posted via Mobile Device
01-18-2013, 01:25 PM | #7 |
Re: HID help
i have the H4 conversion housing with some $30 HID's and no problems and its ben about a year! I didnt have to rewire anything mine was just plug and play took like 5 minutes to install!
01-18-2013, 01:29 PM | #8 |
Re: HID help
yea they are!!! lol think ima get some from ddm though these are acting up.
01-18-2013, 01:33 PM | #9 | |
Re: HID help
01-18-2013, 01:34 PM | #10 |
Re: HID help
i heard about that plug n play but i couldnt find it anywhere, where did you get yours??
01-18-2013, 01:36 PM | #11 |
Re: HID help
is that just so it goes through the rubber boot?
01-18-2013, 01:37 PM | #12 |
Re: HID help
i got them at a flea market here in houston, instead of a harness on the end its just three wires wit a pin on the end and you just stabb them into the harness thats on the truck
01-18-2013, 01:38 PM | #13 |
Re: HID help
and in your guys' opinion is the 55w better than the 35w?
01-18-2013, 01:43 PM | #14 |
Re: HID help
depends on you 55w are brighter, mines are 35w i have no problem with mines just depends how bright you wana go! but i really dont think its too much of a difference in my opinion
01-18-2013, 01:59 PM | #15 |
Re: HID help
I bought some of these: http://www.ebay.com/itm/261136304823...84.m1439.l2649
They came with halogen bulbs and you could put HID bulbs in there. But I bought some 5000K 100/90w xenon H4 bulbs and am using those instead of HID's or halogen bulbs. |
01-18-2013, 02:03 PM | #16 | |
Re: HID help
Then you just need single pattern bulbs in h4. Posted via Mobile Device
01-18-2013, 02:14 PM | #17 | |
Re: HID help
and do you think these are good for the hids?
01-18-2013, 02:26 PM | #18 |
Re: HID help
i also found these. the thing im confused about is exactly which h4 bulb goes in there. these were the various types
01-18-2013, 02:44 PM | #19 |
Re: HID help
The h4/9003 is the style you want.
Advice to all if an aftermarket headlight has that little anti glare shield in front of the bulb it's just trash Get these in the link. http://www.sharphid.com/product_p/hella164ec.htm Posted via Mobile Device
01-18-2013, 02:51 PM | #20 | |
Re: HID help
01-18-2013, 07:59 PM | #21 |
Re: HID help
i would get h4b2 9003 single beam, i have the hi/low and the hid an highs are on same time.
01-18-2013, 08:00 PM | #22 |
Re: HID help
yea.. i can snap some pics for ya
01-18-2013, 08:20 PM | #23 |
Re: HID help
ok i snaped some pics for u...the first pic shows where i cut behind the plug that goes into the factory plug an u can see where i rewired it back together. second pic shows where i cut behind the hid plugs that go into the relay harness for the hids and u can also see where i rewired together. third pic shows u wht it looks like after i cut it. fourth pic is how everything fits threw the rubber boot and how it looks on back of the headlight.
01-18-2013, 08:25 PM | #24 |
Re: HID help
i put the wrong pic for the second one..this is the one
01-18-2013, 08:45 PM | #25 |
Re: HID help
If you want quad hids you will need to wire in a diode as well
