Old 01-18-2013, 11:30 AM   #1
66farmer
66farmer's Avatar
Shorting mirror arm
I want to cut 2-3" off the outside mirror arm and go from the stock 5" round to a 3 to 4" round mirror head. Before I start cutting I thought I would ask to see if anyone has done this and could post some pictures.
Thanks for the help
66farmer is offline   Reply With Quote
Old 01-18-2013, 12:13 PM   #2
1963c-10
1963c-10's Avatar
Re: Shorting mirror arm
Why not get a short 60-61 cast iron mirror arm which is 2" shorter. The 62-66 arms are hollow and the 60-61 are solid.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-18-2013, 12:20 PM   #3
theastronaut
theastronaut's Avatar
Would a shorter arm clear the vent window on a 64-66? I've thought of doing this on my '66.
theastronaut is offline   Reply With Quote
Old 01-18-2013, 12:44 PM   #4
1963c-10
1963c-10's Avatar
hmmm...not sure. Never put one on a 64-66 door. But if it clears for a standard arm, I would think it would for an arm that 2" shorter. Especially is running the factory mirrors w/the bottom stud. It allows the mirror to be adjusted out different than the aftermarket mirrors w/the center studs. I could mail on edown to check if needed though. I have a short arm left.
Old 01-18-2013, 12:47 PM   #5
rideblue00
rideblue00's Avatar
Just cut it and weld it back together
rideblue00 is offline   Reply With Quote
Old 01-18-2013, 01:12 PM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
It's been done by a member on this site. Orange truck, painted bumpers, can't remember his Avatar.
Old 01-18-2013, 04:42 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
It could also be easily done with JB Weld if you could find a piece of smaller tube that was a slip fit inside. Just section the outer tube with a tubing cutter, slip the pieces together with a glob of epoxy, and wipe/sand the outside of the seam when it dries.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-18-2013, 11:59 PM   #8
The Sub
The Sub's Avatar
I did mine. I have one peace glass so the mirror arm doesn't have to be long hope this helps
Jim
The Sub is offline   Reply With Quote
Old 01-19-2013, 09:58 AM   #9
66farmer
66farmer's Avatar
Jim
Jim
How much did you cut off and what size is the mirror head.
Thanks for the help
Old 01-19-2013, 08:56 PM   #10
ol_skool_chevy
ol_skool_chevy's Avatar
I did my old 64.
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-22-2013, 09:37 PM   #11
The Sub
The Sub's Avatar
Originally Posted by 66farmer View Post
Jim
Thanks for the help
I cut 2 1/2 in off. The mirror head is 4 in.
Jim
