Boss 338 wheel fit issues?
As anyone has issues with the Boss 338 wheels fitting over the front hubs on a 1972 C10?
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Boss 338 wheel fit issues?
Yes.
You will need to grind the HUB of the front rotors to clear the inside bore of the wheel. Takes about 5 minutes per side with a flap wheel on a grinder.
Great....
Will the wheel cap still fit? |
Yes.
Have you seen the GIANT Boss 338 thread that started in 2009? http://67-72chevytrucks.com/vboard/s...d.php?t=352320 Look on the last few pages for rotor grinding info.
Thanks a ton.....
I took one less step. Get a 1/4 inch spacer and new lug nuts. In fact it looks better because it pushes the wheel out more. (I even added 1/4 spacer in the rear)
1971 C/10 - Orange & White 2009 GMC 1500 - Lowered 3/4 22' KMC Slides |
#7 | |
I don't want them pushed out any more. That's where everyone is different.
What size are you running in the rear?
