Old 01-18-2013, 01:55 PM   #1
Rich916
Rich916's Avatar
Replace lug bolts?
I want to replace some wheel bolts / lug bolts on my rear axle. I thought there was a tool specific for this. Everthing i'm researching shows BFH and smack it out. Is there a better way?
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 01-18-2013, 02:09 PM   #2
Andy4639
Old member
Andy4639's Avatar
Wink Re: Replace lug bolts?
If your replacing them then yea big hammer works. There no good right so why not. Then put the new one in and tap it in good then turn it over and use a old lug nut to pull it all the way through.
You can use the BH to for installing them for the most part but I always use the old lug nut to make sure it's all the way up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2013, 02:17 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I also use a lug nut but I use a greased flat washer under it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 01-18-2013, 02:26 PM   #4
Rich916
Rich916's Avatar
Ok, bearing a seals are in and the diff's buttoned up. couple bolts are cross threaded and didn't relialize until after. Dont realy want to pull axle. I'll try the BH.
Old 01-18-2013, 02:39 PM   #5
Ol Blue K20
have faith, it'll work
Dale
Old 01-18-2013, 03:19 PM   #6
Fitz
10 ton hydraulic press works well, too if you use a piece of thick wall DOM tubing for a mandrel
Fitz is offline   Reply With Quote
Old 01-19-2013, 12:43 AM   #7
hayhauler71
hayhauler71's Avatar
ths works great also http://www.lislecorp.com/divisions/products/?product=97
Fuzzy
hayhauler71 is offline   Reply With Quote
