Old 01-18-2013, 02:17 PM   #1
GM-power
GM-power's Avatar
Horn
Well my truck horn hasn't ever worked when I press it in; tested the horns and they work. What should I check for between the horn and the steering wheel?
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 01-18-2013, 02:48 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Horn
Horn relay under the dash?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-18-2013, 06:39 PM   #3
big10ratrod77
big10ratrod77's Avatar
Re: Horn
every truck ive bought the horn didnt work and most times you can clean the contact ring under the steering wheel and it will start working
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 01-18-2013, 07:01 PM   #4
cory d
cory d's Avatar
Re: Horn
i horn worked, until i swapped steering wheels then decided it wasnt worth the few minutes to make the horn work so i pulled them off "weight reduction" lol
cory d is offline   Reply With Quote
Old 01-18-2013, 08:32 PM   #5
GM-power
GM-power's Avatar
Re: Horn
Ive lived without it for awhile, but all the idiots on the road need to hear some noise sometimes.
Old 01-18-2013, 10:54 PM   #6
wilkin250r
wilkin250r's Avatar
Re: Horn
It's most likely the horn contact ring, or the relay under the dash.
Do you know how a relay works? I can't remember the terminal pinout, but I can help walk you through a test for the relay.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 01-18-2013, 11:34 PM   #7
king-918
king-918's Avatar
Re: Horn
Sounds like it's time for a train horn
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-19-2013, 03:08 AM   #8
zaccaglin
zaccaglin's Avatar
Re: Horn
2nd that.
I busted mine when i swapped out my ignition cylinder. So instead i hooked up a pushbutton to the horn wires coming from the steering column and to ground and just mounted it in the dash. Works for me.
Zaccaglin
1998 Chevrolet C1500 Ext. Cab 350
Former Rig:
1985 Chevrolet K20 Suburban 6.2L Detroit/TH400/NP208
zaccaglin is offline   Reply With Quote
