Old 01-18-2013, 03:54 PM   #1
JointTech
JointTech's Avatar
switched 12v under the hood
I need some power for my new electric choke carb. They say dont come off the coil, hei or alternator.
Any ideas on something else to tap onto without running a new wire from inside the cab?
72 C20
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 01-18-2013, 08:45 PM   #2
chiefcfd
chiefcfd's Avatar
Re: switched 12v under the hood
It would be best to run a wire to the fuse panel. Tap into an unfused switched terminal.
chiefcfd is offline   Reply With Quote
Old 01-18-2013, 10:21 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: switched 12v under the hood
Battery!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-19-2013, 12:01 AM   #4
ole dollor
ole dollor's Avatar
no not from the battery....shame on you.lol
ole dollor is offline   Reply With Quote
Old 01-19-2013, 07:55 AM   #5
Andy4639
Old member
Andy4639's Avatar
Yea I went back and read the OP and said switched power. Sorry, How about coming off the starter wire terminal.
Old 01-20-2013, 06:40 AM   #6
JointTech
JointTech's Avatar
I ran it out of the fuse box i was debating which one to use and now cant remeber if I used a spare slot or the cig lighter. Then I got home tonight and couldnt remember if the cig lighter is even switched. doh. I only tested with a voltmeter with the switch on. ill check that out tomorrow.
on the positive side the truck fired right up with the new carb and choke.
72 C20 Long Bed
Old 01-20-2013, 07:55 AM   #7
Andy4639
Old member
Andy4639's Avatar
Cig liter is hot all the time. Well in my71 it is anyway.
Old 01-21-2013, 09:44 PM   #8
JointTech
JointTech's Avatar
yea the cig lighter is always on. went out today and the battery was completely dead. Switched it to the old radio fuse.
72 C20 Long Bed
Old 01-22-2013, 07:12 PM   #9
JointTech
JointTech's Avatar
pffft had a couple millivolt draw with ignition off on the radio as well. Battery is getting a workout.
Changed it to another switched free spot in the fuse box and tested it at 0.00mv with ignition off.
72 C20 Long Bed
