Old 01-18-2013, 04:51 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Headers
What do you think?
I have the Ram horns on my truck now but found these for $100.00.
Would it be worth swapping them out.
Good and the bad comments welcomed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-18-2013, 05:46 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Headers
You will see no performance benefit from using headers that short. They are a nice ceramic coated set that will look good in your engine bay. But the Ram horns will probably flow just as good.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-18-2013, 05:56 PM   #3
Lee H
Lee H's Avatar
Re: Headers
I would only change to these from stock if they are ball/socket at the collectors and 3/8s flanges. Otherwise you'll be chasing leaks.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-18-2013, 05:57 PM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Headers
This is what I want to know. I figured this to. I can get my horns coated I guess and come out better.
