Old 01-18-2013, 08:05 PM   #1
doubleb's69
doubleb's69's Avatar
dual snorkel air cleaner how to.
I already now it has been done and there is another thread on the site that shows pics but I thought I would share the pictures and what I used to make it for anyone who wants to do it themselves. A buddy of mine just built a 383 for his 72 C/10 and wants to make it look stockish and wondered if I would build him one so here is how I did it. There are probably a million ways to do it and different tools to use but these are the ones I used to get to my end result.
Parts list: two air cleaners you don't mind cutting up.
Tool list: drill, cut off wheel, 1/8 inch drill bit, 1 & 1/2 inch hole saw, wire wheel, a vise if you have one, mig welder, die grinder with a carbide bit, vise grips, small screw driver or chisel, and a small hammer.
I started by putting the worst of the two air cleaners in a vise. I then put the 1/8th inch drill bit in the drill and slowly drilled out the factory spot welds. There is one on each corner or 4 total.
After drilling I used a small screw driver and a hammer to lightly pry up the air horn from the air cleaner.
I then drilled out the two spot welds that hold the heat valve to the air horn. I also used the screw driver and hammer to help remove this on both air horns. (This is optional but he wanted it to be smooth.) After breaking the valve loose I wiggled it around to unhook the rod from the flap inside of the air horn and removed the valve all together. I then cut off the end of the rod that runs from either side and pulled it through to remove the valve from within.
After all of the the removal of parts on the air horn I mocked up the general location to make sure all was right and it would work.
Bud
doubleb's69 is offline   Reply With Quote
Old 01-18-2013, 08:22 PM   #2
doubleb's69
Re: dual snorkel air cleaner how to.
I then removed the clamped on air horn and I cut off the heat riser tube (optional) on both air horns to allow more air in and cleaned it up with a grinder and file.
I then went to the first air cleaner and cut out the flange so it could be utilized in the second base so that there would not be any gaps and look factory from the outside. I cut it 2 inches on both sides and at the bottom and top as far as I could. I drilled four 1/8th inch holes in the flange for spot welds to secure it the the air cleaner. One in each corner. I then set it aside for later.
I moved on to where I decided I would put the snorkeld on air cleaner #2 and measured it out. I used a 1 and a 1/2 inch hole saw on both ends of the measurement and a cut off wheel to connect the two. I then used to die grinder with the carbide bur to modify the opening to slip the flange from air cleaner #1 into air cleaner #2.
I then slipped the flange in from the inside of the air cleaner. I took the air horn and fitted it over the flange to make sure everything was level and symetrical to the other air horn. After I had it where I wanted it I used vise grips to secure it while I spot welded it.
Bud
Old 01-18-2013, 08:34 PM   #3
doubleb's69
I then refitted the air horn over the flange and spot welded it as well. I used the die grinder and carbide bur to smooth out the welds since they where in a tight area.
This is how I did mine and like I said there are probably easier ways out there but if you have a few hours to kill and have the parts it is very easy.
I will be welding up all of the holes and then sand blasting it. After that I will put some putty on the air horns and smoothing them out. I will follow it up with some semi gloss black on then it will go to its new home.
Bud
Old 01-18-2013, 09:01 PM   #4
black_sheep454
Looks good
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 01-18-2013, 09:02 PM   #5
shawno72
C/10 junkie
shawno72's Avatar
I like it
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-18-2013, 09:07 PM   #6
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work Bud!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-19-2013, 02:18 PM   #7
doubleb's69
Thanks fellas. I will be putting a later model lid on it so that we can fit a 4 inch filter under in it.
Here is the engine it will be going on.
383 with flat tops, Dart heads, Edelbrock Performer RPM, and Comp Cams 292 magnum .501/.501 with 244 degrees at .050 and 110 lobe seperation. It oughta run and sound pretty good.
Bud
Old 01-19-2013, 03:01 PM   #8
big_al_71
big_al_71's Avatar
Man I love when someone builds something rather than buying it..Great write up.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-19-2013, 03:10 PM   #9
GRX
GRX's Avatar
x2,127,489
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 01-19-2013, 07:57 PM   #10
robzilla
robzilla's Avatar
going to have to make one too, got to find another air cleaner, as i got rid of the extra one i had....
robzilla is offline   Reply With Quote
Old 01-20-2013, 08:10 AM   #11
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Been planning one of these for a while now. I just have to cross off the 994 things on the list before it!
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 01-20-2013, 08:37 AM   #12
RANDY COX
RANDY COX's Avatar
Kool good job,I made me one of those a few yrs back for my Blazer..there's nothing like OEM...extra parts laying around...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-20-2013, 12:48 PM   #13
doubleb's69
Thanks guys. I made this one for a friend using my last two air cleaners I had. Now that I see the results I need to find two more to build one for myself . I will post pictures after it is finished and painted and in the truck.
Bud
Old 02-09-2013, 05:04 PM   #14
doubleb's69
Here are a couple updated pics. Still trying to locate a 88-92 single stud TBI air cleaner lid so we can run a 4" filter.
Bud
Old 02-09-2013, 05:11 PM   #15
shawno72
C/10 junkie
shawno72's Avatar
Looking real good.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 02-09-2013, 06:10 PM   #16
yuccales
yuccales's Avatar
That looks real nice!
yuccales is offline   Reply With Quote
Old 02-09-2013, 07:33 PM   #17
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Sweet man, good job
John
1999 Toyota Tacoma 4x4
Old 02-09-2013, 10:27 PM   #18
That came out nice! I made one using later snorkels that are shorter and bigger
Old 02-11-2013, 10:58 AM   #19
doubleb's69
I think I finally located a lid. I will blast it and paint it as soon as I get it.
Bud
Old 02-11-2013, 11:39 AM   #20
weever82
weever82's Avatar
Awesome job! You are a good buddy to be doing that for him!
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 02-11-2013, 02:46 PM   #21
GTJ558
i have a tbi chrome air lid with script edelbrock never been used...its basically been wall art since i bought it many years ago when i had my blazer.
GTJ558 is offline   Reply With Quote
Old 02-11-2013, 04:19 PM   #22
doubleb's69
I just got a lid today. It is off of a 72 Monte Carlo so it isn't as tall but I can still fit a 3" filter under it. I wanted a TBI lid because they have a 4" filter.
Bud
Old 02-11-2013, 05:16 PM   #23
GTJ558
no problem i figured id chime in maybe give a little help. glad you got a lid.
Old 02-11-2013, 06:03 PM   #24
54blackhornet
54blackhornet's Avatar
Question ? Would 2nd horn increase heat to carb if you had both connected to the vacume controller ? Like two heat risers off both manifolds open to warm up then close off when warm . IT IS COLD IN OREGON !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 02-11-2013, 06:40 PM   #25
rambler
MOVE OVER
rambler's Avatar
nice write up.. I want to to do this someday,, just got to get the truck running again
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
