Old 01-18-2013, 10:59 PM   #1
jayoldschool
Moderator
What's this lever on the dash?
Anyone know what that lever on the left side of the dash is for?
jayoldschool is offline   Reply With Quote
Old 01-18-2013, 11:01 PM   #2
ol_skool_chevy
ol_skool_chevy's Avatar
Re: What's this lever on the dash?
Air Brakes?
whats it say on it? i see writing...maybe post a photo closer
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-18-2013, 11:01 PM   #3
DoubleL
DoubleL's Avatar
No matter what you do don't pull that lever!! I have no idea what it does but it looks scary
My 1965 C-20 project
https://67-72chevytrucks.com/vboard/...d.php?t=835095
DoubleL is offline   Reply With Quote
Old 01-18-2013, 11:03 PM   #4
ol_skool_chevy
Ejection seat?
Mark with Chalk
Cut with a torch
Old 01-18-2013, 11:08 PM   #5
RANDY COX
RANDY COX's Avatar
Why that's a rear-end Locker...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-18-2013, 11:09 PM   #6
RANDY COX
RANDY COX's Avatar
Jake Brake...
1964 BBC 402 4x4
Old 01-18-2013, 11:14 PM   #7
jayoldschool
Moderator
Doubt it's a jake. This is on a 230 6/3spd.
Keep the guesses coming!
Old 01-18-2013, 11:14 PM   #8
Hx16457
Hx16457's Avatar
ditto!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 01-18-2013, 11:22 PM   #9
jdl71
jdl71's Avatar
Most likely a Mico Lok. http://www.mico.com/
It's basically a hydraulic emergency brake. You press the brake pedal down, flip the lever, and it holds the pressure on the brakes until you release the lever. I've seen several of these trucks with that. Pretty sure it was an aftermarket add on, but the lever always seems to be in that same spot. I even had a parts truck not too long that didn't have the lever, but did have the hole in the dash and the surround still there.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 01-18-2013, 11:24 PM   #10
jdl71
jdl71's Avatar
BTW, I can't tell clearly from your picture but does your e-brake handle happen to be missing?
Psalm 23
64 C10
66 K20
Old 01-18-2013, 11:30 PM   #11
jayoldschool
Moderator
Not sure, haven't got the truck yet. Where should it be? That may explain why the Mico lock is there! Nice call, btw. That looks exactly what that is.
Old 01-18-2013, 11:43 PM   #12
ABX131
ABX131's Avatar
Your ebrake is missing, it sould be under the steering wheel on the left side. It sure looks like a hydraulic brake lock to me.
ABX131 is offline   Reply With Quote
