HEI Hook UP... What WIRES WHERE?
I am going to hook up ignition next week on my build. I am wondering if there is a write up or if someone can tell me what wires I need to put where on my HEI hook up.
I am going from the stock set up to the HEI. Thanks pics welcome!
Confidence is the feeling we have before we fully comprehend the situation |
Re: HEI Hook UP... What WIRES WHERE?
Simple!
Run a dedicated 12 gauge wire from an unfused plug on your fuse block to the battery plug in on your hei. |
![]() Join Date: Aug 2010
I tried running a wire to an open fuse plug on my fuse box but every plug either received power all the time, when the lights were on, or didn't have enough power to produce spark when in crank. What I am going to have to do is branch off of the ignition wire on the back of the ignition switch. There might be something wrong with my fuse box but I've heard of others having the same problem
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's a little more on the subject by fellow member Ray McElvoy.
.............http://rmcavoy.freeshell.org/HEI.html
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
#5 | |
Did the same on my 65 and same thing. Used a test light to find a plug in and a voltmeter to check the output. Worked for me. Maybe the 2 halves of your fuse box aren't plugged back togethor quite right. |
#6 | |
#7 | |
![]() Join Date: Mar 2011
If that doesn't work you have problems that need to be addressed - those kind of problems often result in fire.
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
![]() Join Date: Jan 2012
heres a thread on how to do the swap http://67-72chevytrucks.com/vboard/s...ad.php?t=13698
and heres a link to a labled fuse box http://67-72chevytrucks.com/vboard/s...d.php?t=121515 ign unfused is top right corner beside the screw in the pic, i hooked my hei up to the ign unfused as well and it works awesome |
Accel (im sure more do to) offers a plug that has the power and tach wire in one nice little plug. I just got mine for $12 at Pep Boys. Run your power and tach wire together from inside the truck and POW HEI is in full effect.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
#10 | |
#11 | |
![]() Posted via Mobile Device |
Awesome. This just helped me as well. Thanks guys!
Bud |
