Better late than never
![]() Join Date: Dec 2001
HELP PLEASE with door glass install
Please help, I'm going crazy trying to get the doors back together. After the window is in, I can't get the vent in. I know it is 1st turned 90 degrees, but how do you get the vent past the opening between the window glass and the part of the frame that sits under the vent handle?
1970 C/10 SWB Stepside |
I hope I can help you. You install the window and let it go right to the bottom of the door then insert the vent window like you said. Keep everything loose until you get the vent window in place. You may have to angle the window glass slightly to the back. Don't force it as it may cause damage. Take you time. Have a beer and it will go together. Good luck.
Thanks Western Star. I still can't get it. I've got the door flat on a table. I think I will install the door 1st, maybe that will be easier.
faster, faster, faster
Vent window first. It's the only way I know to do it.
I'm going to Law School, wanna debate? It's good practice. |
You install they way you took it out. If you put the vent window in first then there is no room for the window to slide in on the angle you need. Make sure the bottom guide for the window crank mech is not bolted up or you can't get the window low enough to get the vent window / window track in.
I have done it with the vent window in first. How do you think you replace a broken window? It's not by taking the whole vent window out, it'll go in just fine you just can't force it.
I'd be interested in seeing that done,haven't been able to "bend" the glass enough to fit it in the track- what am I missing?
you never have too many suburbans.... |
Exactly..........Glass doesn't bend. I would like to see someone take a window out without removing the vent window.
I would be interested in seeing the door window installed after the vent window is in place, also.
Jim |
I did it on my truck it just takes a little finess an time i had it in in about 1/2 hour with the ventwindow in just my .02
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren ![]() http://www.myspace.com/dmurphy68 |
dmurphy68
Will you let us know how you did it? Jim |
I just put my vent window in and then slid my window in at an angle and the pushed it back twards the back of the truck into the felt and then slid it into the vent window track after i hooked upthe sliders. it took a little finess but it worked.
Darren
#13 |
You da man.
#14 |
Told Ya it's not that hard.
#15 |
Nothing clever
so what did we decide? cause I need to do this job when I get home!
I gots me a shattered passenger window to deals wit |
#16 |
I always loosen the screws for the rear glass chanel. This way, it gives ya more room to work with.
