Old 01-19-2013, 02:17 PM   #1
Pro Performance
Pro Performance's Avatar
Pro Performance: Pro2 Air Management with Porterbuilt Brackets
New!
We just added a new version of our Pro2 air management kit. This kit is the same as our standard Pro2 system, but will include the Porterbuilt brackets to bolt the air management system to your 63-72 C10. It will come complete with dual VIAIR 444C compressors, dual 3 gallon aluminum tanks, AccuAir VU4 manifold and all DOT fittings to plumb right into your bags. Of course, this will be an upgraded option to our Pro Series air ride kits for the 63-72 C10's.
Price: $1,450.00
We will be taking $50 off the price as a special for this kit. This will run through the end of February. It will be an early February special.
Pro2 Air Management Kit w/ Porterbuilt Bracket - 63-72 C10
Pro2 63-72 C10 Air Management Kit Includes:
2 - Porterbuilt Bolt-On Air Management Brackets
2 - VIAIR 444C Chrome Compressors (200 PSI)
2 - 3 Gallon 200 PSI Rated Aluminum Tank (6 Port)
1 - AccuAir VU4 Valve Block
1 - AVS Arc-7 Switch Box
2 - VIAIR 160 PSI White Face Gauges, Illuminated
1 - 165/200 VIAIR Pressure Switch
1 - 250 PSI Safety Valve
2 - VIAIR 40A Relays
1 - 60A Inline Fuse Holder
2 - Drain Valve
1 - 50 Ft. of 3/8" DOT Approved Air Line (Bags)
1 - 75 Ft. of 1/4" DOT Approved Air Line (Gauges)
4 - 1/8" FNPT - 1/4" Barb
4 - 1/4" MNPT to 1/4" Hose
1 - 1/2" MNPT to 1/8" FNPT Reducer
4 - 1/4" MNPT Plug
2 - 1/4" MNPT to 1/4" FNPT Elbow
2 - 1/2 MNPT to 3/8" Hose, 90 Degree
4 - Bag Fittings (Select size under options)
Pro2 Air Management Plumbing Diagram
Pro2 Air Management Wiring Diagram
Pro Performance is offline   Reply With Quote
Old 01-20-2013, 12:32 AM   #2
andrewmp6
Re: Pro Performance: Pro2 Air Management with Porterbuilt Brackets
How much for the brackets alone?
andrewmp6 is offline   Reply With Quote
Old 01-20-2013, 01:17 AM   #3
chad64chevy
chad64chevy's Avatar
x2 on just the brackets, i already got the compressor and tank
chad64chevy is offline   Reply With Quote
Old 01-20-2013, 11:27 AM   #4
Pro Performance
The brackets are $79 each or $150 for the pair.
- Travis
Old 01-20-2013, 11:59 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Travis,... I just realized that these are RH and LH specific boxes.
(so I guess you would need to know which side the customer wants to install these on)
I sent you a PM to order a "pair" of boxes.
1 LH and 1 RH box.
Keith
Convert to disc brakes.
Old 01-20-2013, 12:15 PM   #6
Pro Performance
Keith,
PM received and returned.
Yep, if ordering one, need to know which side. You took the last pair I had in stock, but will be getting more soon.
- Travis
Old 01-20-2013, 12:31 PM   #7
lolife99
lolife99's Avatar
Paypal sent!
Keith
Old 01-21-2013, 12:08 PM   #8
blfuller123
blfuller123's Avatar
Can you get the interior dimensions? Im thinking these would be perfect for battery boxes with the tanks installed instead of a place to mount the compressors.
blfuller123 is offline   Reply With Quote
Old 01-21-2013, 12:54 PM   #9
Pro Performance
I gotcha, but it would have to be a very small battery. The inter dimensions are not exactly square, so it is appx. 4.875" wide on one side, and 5.5" on the other, and appx. 12" long.
- Travis
Old 02-16-2014, 02:33 PM   #10
stomper
Junior Member
stomper's Avatar
Price on your website is $1450. Is there a discount code?
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 02-17-2014, 02:12 PM   #11
Pro Performance
This is old pricing, but give me a call and can get you all setup with the discount.
Travis
480-420-8175
Old 02-17-2014, 09:29 PM   #12
jtp67-72
jtp67-72's Avatar
1 LH and 1 RH box.
My pics are traveling now!!.....lol....they are quality pieces and i can't reproduce them for the price!!.........good deal on the air setup Travis
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 02-18-2014, 01:34 AM   #13
fastpace
Man all these discounts and specials rolling out right after I ordered all my stuff, always seems to happen that way.
1972 C10 LWB Highlander Dark Olive/White - Work in progress 5.3/6L80e, Accuair e-level, Porterbuilt Stage 1 front and Stage 2 rear, Wilwood 14"F 13"R, Vintage Wheel Works V40 18x8/18x11, and more... Build Thread
fastpace is offline   Reply With Quote
Old 02-18-2014, 01:57 PM   #14
Pro Performance
Thanks…. it is one of our most popular air management kits.
No worries, I got you all setup when you ordered... Your truck is going to nice!
Old 08-03-2015, 07:22 PM   #15
biohazardbill
What are the small holes for that are on the side with the big hole?
biohazardbill is offline   Reply With Quote
Old 08-03-2015, 07:29 PM   #16
Pro Performance
The design has changed since this post, but I am not entirely sure, to be honest.
Old 08-04-2015, 11:09 PM   #17
jtp67-72
jtp67-72's Avatar
To mount the compressor.....
Old 08-04-2015, 11:39 PM   #18
Pro Performance
I thought he was referring to the small holes on the end cap.
Old 08-06-2015, 12:20 AM   #19
jtp67-72
jtp67-72's Avatar
I was thinking the side with the BIG hole....lol....I don't think i used those on the end....jim
