Old 01-19-2013, 08:40 PM   #1
arturo7
arturo7's Avatar
Which Brush for POR?
What type of brush gives the best results when applying POR?
thnaks
ever forward
build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542073
arturo7 is offline   Reply With Quote
Old 01-19-2013, 09:57 PM   #2
OrrieG
OrrieG's Avatar
Re: Which Brush for POR?
I used dollar store 1.5 - 2" ones, they can't be cleaned or reused. Here you can get a 3 pack for a buck. I use the same for fiberglas too.
OrrieG is offline   Reply With Quote
Old 01-20-2013, 12:09 AM   #3
Coach529
Coach529's Avatar
I have used a 4" wide foam roller on floor pans with good success.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-20-2013, 06:52 AM   #4
S10Fan
Old Heap Driver
Harbor Freight, various sizes, cheap.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-20-2013, 07:08 PM   #5
mr48chev
mr48chev's Avatar
Lots of cheap throw away brushes available. I used to buy "chip" brushes from the paint store dirt cheap when I did the parts buying for a food processing plant. No brush cleaning solvent in the plant to contaminate anything was one reason and no expensive brushes being pilfered was a secondary reason.
My ongoing truck projects:
Old 01-21-2013, 08:47 AM   #6
focusedontheprize
focusedontheprize's Avatar
I was using the cheap bristle brushes for a while. My biggest complaint about the was when the bristles would start separating from the brush and would end up in the paint. So I moved over to foam brushes and I will say they worked great. Still laid down thick, but the end result was a smooth finish.
focusedontheprize is offline   Reply With Quote
Old 01-21-2013, 01:55 PM   #7
rollinrooster
rollinrooster's Avatar
I agree... foam brushes seem to work best.
rollinrooster is offline   Reply With Quote
Old 01-21-2013, 08:09 PM   #8
_Ogre
_Ogre's Avatar
cheap chopped chip brushes
shop air compressor timer
Old 01-22-2013, 08:28 PM   #9
arturo7
arturo7's Avatar
Thanks guys.
A couple follow ups...
How well does POR handle heat? Would it be OK for the underside of the hood? What about on the alternator bracket?
ever forward
Old 01-22-2013, 08:44 PM   #10
Chevette
Chevette's Avatar
Originally Posted by arturo7 View Post
Thanks guys.
http://www.por15.com/Data%20Sheets/por15sum.pdf
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 01-22-2013, 09:39 PM   #11
arturo7
arturo7's Avatar
Thanks, Chev. I've read and re-read the specs. Just hoping for some empirical feedback.
ever forward
