disc brake master ?
if a guy was to do the disc brake swap could he still run the single non power master cylinder or have to go to a dual master cylinder
Hell yeah!!!
Re: disc brake master ?
Definitely go to a dual with either a proportioning valve or adjustable valve for the rear brakes if keeping the drums.
Stock is good but custom is the sh*t! |
ok thanks i might just rebuild the front drums for now then
#4 | |
![]() Quote:
And nothing wasted(except maybe a $16-mc), as when you later go to discs, you will already have the dual system, lines, etc. [And, you can prolly be ok w/out a prop valve--at worst, should your rears catch too soon, you could install an adjustable valve on the rear line, like nachodog2 said above; this valve can be used when you later go to discs.] You can buy a reman'd dual mc for about $16 from locals like A-Zone, Adv. A/P, O'Reilly's. Luck to you, Sam |
