01-20-2013, 03:39 PM | #1 |
WTB BBC crossmember and clam shells
Looking into options for my 72 Blazer 4x4, would like to find a crossmember and clamshells to be able mount a BBC. posting here because Blazers did'nt come with a BBC.
Thanks for the help |
01-20-2013, 04:01 PM | #2 |
Roadtrip!
Re: WTB BBC crossmember and clam shells
Actually, 4x4s didn't come with a BB either. You will have to use the small block setup or i believe there is an aftermarket BB setup.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
01-20-2013, 06:11 PM | #3 |
You can use the square body engine crossmember with the square body clams. I think you have to drill a couple of holes to make it happen.
01-21-2013, 12:01 AM | #4 | |
Thanks for the info, I will have to find that set up then. I appreciate the help, will have to post in the square body section. |
01-21-2013, 12:50 AM | #5 |
Member #1049
Monte, no need to change anything, a big block will bolt right up to the small block crossmember, Although to put a big block in a 4X4 you will either have to clearance the firewall for the HEI and valve covers, use a body lift to gain clearance, Or move the engine/trans/transfer case forward a couple of inches.
01-21-2013, 01:11 AM | #6 |
I have a set if you want to go that route....
01-22-2013, 03:36 AM | #7 | |
Thanks, will hold off until I get more info on whats needed for the change. |
01-22-2013, 12:05 PM | #8 |
Member #1049
Monte, you do not need anything else, the small block rubber mounts bolt right onto a big block and since you are going with a 700R4? it would make it the easiest swap leaving the transfer case and drivelines in the factory location.
Although I will admit using a 73 up crossmember and clam shells makes for a nice upgrade to a sturdier mounting system and added clearance in case you ever need to remove the oil pan, plus more clearance from crossmember to front axle pumpkin on a stock height 4X4. Last edited by Livrat; 01-22-2013 at 12:05 PM. Reason: spelling |
01-22-2013, 02:09 PM | #9 |
Thanks Mark, think I will try it with the 73 up cross member to make it look right and be sturdy. Plus you never know when you will have to pull the pan off, stranger thing happen. Hows WA these days.
01-22-2013, 02:12 PM | #10 |
well it looks like I'm back on line for looking for a set up, if anything I'll have both to see which works better. What are you looking to get for the set up and if you don't mind could you get a picture of it. Thanks
01-22-2013, 02:26 PM | #11 |
I have an auto tranny crossmember out of a 71 Big block truck.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-22-2013, 03:03 PM | #12 |
01-22-2013, 03:04 PM | #13 |
Gotcha. Sorry about that.
