01-20-2013, 07:59 PM | #1 |
aluminum vortech heads
Does anyone know if an 04 5.3 litre aluminum heads will fit on a 70s 350 block
01-20-2013, 08:02 PM | #2 |
Location: Marshall, NC....heart of the Appalachians.....aka, Gods country!!
Re: aluminum vortech heads
unfortunately they will not!
01-20-2013, 08:07 PM | #3 |
Do you know what years of vortech aluminum heads will work?
01-20-2013, 08:19 PM | #4 |
never made a factory vortec head in aluminum that will fit a gen 1 sbc...that I'm aware of??? The LS series engines that have the heads I think your referring to share virtually nothing with the gen 1 engines. 96 up 350 vortec's that come in trucks and vans have iron heads that will bolt on a gen 1 sbc if you use a vortec specific intake manifold....have a set on my 84 350 and they work well but are limited in valve lift capability in stock configuration.
01-20-2013, 09:05 PM | #5 |
towbar is correct...............you can get the L31 Vortec heads off like a 96 chevy truck and they are bolt on however you have to get a Vortec style intake manifold. Scoggins Dickie as well as others offer them in a high lift option for bigger cams. The factory Vortec heads offer 30-40 hp right off the shelf. Retaining a older style engine and using these heads is a awsome way to get cheap power.
72 Chevy LB, LS in the works, 4L80, Grandfather bought it brand new. 66 GMC Short Step, 84 Front Suspension, many more mods to come 67 Chevy 3/4 Ton, 327, Auto, Factory A/C Ya must have been movin cause I was haulin a*$ when I passed you |
01-21-2013, 01:01 AM | #6 | ||
"I ain't nobody, dork."
No modern LS based heads (4.8, 5.3, 6.0) will fit first or second generation SBC's.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-21-2013, 11:29 AM | #7 | |
Thanks Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
01-21-2013, 11:34 AM | #8 |
I know JEGS offers an aluminum casting of the vortec heads...
http://www.jegs.com/i/GM+Performance...FUZgMgod_3QAhg
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
01-21-2013, 02:56 PM | #9 |
http://www.crankshaftcoalition.com/w..._cylinder_head
Check the WIKI at the link above and it will tell you all about them. If somebody has them they will know them as L31 Vortec. Or should I sometimes give to much credit.
