Old 01-21-2013, 08:30 AM   #1
4DSEVEN
4DSEVEN's Avatar
Fender lace or welting? yes/no?
Are any of you using the welting or caulk in between the fenders?
Any recommendations?
Also inside the cab there is a small channel that looks like it was for interior strips (possibly for panels) anyone know what this is? I am debating if I should strip these off to make the cab walls smooth. I don't have a picture of what I am talking about but they run parallel to the door etc.
4DSEVEN is offline   Reply With Quote
Old 01-21-2013, 11:01 AM   #2
1952
1952's Avatar
Re: Fender lace or welting? yes/no?
good morning 4dseven
those channels are for the windlase cab seals
they go around the top and sides to hold the cab seal
1952 is offline   Reply With Quote
Old 01-21-2013, 11:50 AM   #3
Speedbumpauto
Speedbumpauto's Avatar
I didn't want the look of welt on my 55 so I used Eastwood brush on seam sealer on all the flanges where welt would go and any other bolt on parts that were metal to metal. I masked it off so I didn't get sealer where I didn't want it, let it dry and then installed the parts. I don't know if it was wasted labor or not but it went together nice, looks good and probably won't squeek or rattle and certainly not rust.
Speedbumpauto is offline   Reply With Quote
Old 01-21-2013, 02:32 PM   #4
youngrodder
youngrodder's Avatar
Personally I don't care for fender welt. I used 3M strip caulk between all body panels (including the fenders). It's inexpensive ($20 for entire box which is more than enough). It never dries out. It works the same but I think looks cleaner over all.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-21-2013, 07:34 PM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Your truck looks great. But what's the purpose of this stuff? Our trucks didn't come with anything between the fenders & bed so I wonder about putting anything in there that may trap moisture?
Dan in Pasadena is offline   Reply With Quote
Old 01-21-2013, 07:44 PM   #6
_Ogre
_Ogre's Avatar
i used fender welt on my 58 and like the look.
my bed sides had waves and didn't fit perfect (shocking, i know )
i stuck the welting on the fenders with double sided tape
shop air compressor timer
Old 01-22-2013, 11:28 AM   #7
youngrodder
It basically just forms a gasket when the strip caulk squished down from tightening the bolts. It would work simularly to welt. It helps keep water from sitting in between the panels. It also helps to cut down on any squeeking that might occure from two metal panels rubbing on each other.
Marc
