Old 01-21-2013, 12:35 PM   #1
hotrod1
56 - autocross
hotrod1's Avatar
Fuel Line Frame Clips
Going to run EFI and would like a solution that manages the two fuel lines. Here is one. Anybody else have any other ideas or places to get them. This one is one that someone made. Would like to be able to buy something.
hotrod1 is offline   Reply With Quote
Old 01-21-2013, 01:42 PM   #2
DesertCat
DesertCat's Avatar
Re: Fuel Line Frame Clips
Summitt, Jegs, Speedway, So-Cal Speed Shop, Ebay.....
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131
DesertCat is offline   Reply With Quote
Old 01-21-2013, 02:22 PM   #3
youngrodder
youngrodder's Avatar
I used two of those line clamps that are metal and rubber that you can pick up at most hardware stores. I just inverted one and drilled one hole in the frame. Then you use one screw to go through booth clamps. It worked great an best of all it was cheap. Here is a pic.
If you insist on spending more $$ these would be an option.
http://www.kugelkomponents.com/zenca...index&cPath=18
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-21-2013, 03:25 PM   #4
OrrieG
OrrieG's Avatar
I used the same as young rodder for fuel and brake line. Were the size was al little off I used a short section of split hose as a filler. I used recessed hex chrome bolts on the exposed side of the frame.
OrrieG is offline   Reply With Quote
Old 01-21-2013, 08:06 PM   #5
_Ogre
_Ogre's Avatar
same as youngrodder here too, with a drill point screw. no one will see your fuel line supports
shop air compressor timer
Old 01-22-2013, 11:47 AM   #6
98layinframe
98layinframe's Avatar
Factory s10 clips work great! The ones i pulled off my frame are plastic and hold a 3/8", 5/16", and 2 1/4" lines. I assume they can be purchased from gm? You can see the white clips holding my lines in place.
91 s10 - bagged bodydropped 4", 350/700R4, narrowed reared, cantilever rear air bag setup
1951 chevy 3100 - in build/acquiring parts process. Have full C4 Corvette suspension front and rear, tpi 350, 700r4, 18" torque thrust II wheels
98layinframe is offline   Reply With Quote
Old 01-22-2013, 11:48 AM   #7
98layinframe
Double post..
Old 01-22-2013, 03:07 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
I used these. I believe I got them from jegs
Kabwe is offline   Reply With Quote
Old 01-22-2013, 07:00 PM   #9
Kim57
Kim57's Avatar
I used the Kugel ones. Got them at a shop in Orange Ca. A box of them goes for around $16.00.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
