How much does it weigh?
I was needing to know the weight of a stock 67 SWB chevy with PS, PB and only heat. Thanks, Wayne
Re: How much does it weigh?
3300 LBS dry.
Since you didn't give a full description here are some '67 curb weight numbers for you.
C10 I-6 stepside 3404 lb I-6 fleetside 3478 lb C10 V-8 stepside 3538 lb V-8 fleetside 3611 lb Add in power brake booster 24 lb power steering 33 lb (intergral) This should get you close. Interesting that the trucks added about 135 lb more by '72.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
![]() Join Date: Jan 2002
As a reference point. My 3/4t 2wd big block sierra grande scaled at 5100 lbs today with no one in it. So 3600-3700 lbs is probably pretty close.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Thanks for the info guys. I was trying to get an idea of the weight cause I plan on taking the truck to the strip in the spring and trying to get an idea of possible times in the quarter. More info on the truck 1967,ps, pb swb heater stereo with amp and speakers. Motor is an aluminum headed 434, made 585hp, a turbo 350 with 3200 stall and a 12 bolt with 373 gears. Has a 600/244 Comp Cam hyd. roller with an ultra hp holley 950 and msd ign. There is a feed store close by so I may try and go there to getan accurate weight. I'm thinking about 3550 lbs..Thanks again , Wayne
I'm guessing your quarter mile times will be in the mid to low 11's at about 112 mph.
Posted via Mobile Device |
Its funny how things like this happen, I just weighted my truck today @ the recycle plant. ( 4070lbs )
Truck specs 68 SWB fleet, 327,200r4, PS, PB, 12bolt eaton posi, (i was in it as well 220lbs) I have been lifting my truck on my 2post lift that is rated at 6000lbs, & I was wondering how much the truck truly weighted. So I took it down their and they let me weight it for free.... Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
Seams 3850 is a little heavy but guess I will know in a few days. I'm putting a new posi unit in this weekend with the 373 gears. Many thanks, Wayne
