Old 01-21-2013, 05:25 PM   #1
TwoFiftyShifter
96 Silverado won't start
My daily driver won't start. 96 vortec 5.7 l 1500 4x4. 290k on the truck, motor was rebuilt at 180k. Fuel pump comes on when I cycle the key, used a gauge to find it it is cranking at 61psi. I put a new battery on, tested for spark, which I got good blue spark, and nothing. I put a new starter on, no dice.
It cranks fast, then slow, then wont really crank, then back to cranking fast again. It coughs here and there but doesnt start. I poured 2 gallons of gas into it just in case it was low on gas.
Any suggestions?
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 01-21-2013, 06:06 PM   #2
sntrym95
sntrym95's Avatar
Re: 96 Silverado won't start
How is the oil level?
Mike
sntrym95 is offline   Reply With Quote
Old 01-21-2013, 06:12 PM   #3
TwoFiftyShifter
Oil is in the safe zone, DUDE. I am reading up on an ignition module now on here and google.... this could a littld get a little pricey!
1982 K10 SWB
Old 01-22-2013, 12:48 AM   #4
sntrym95
sntrym95's Avatar
Good to see you know where my avatar is from!
When you said you had 'good blue spark', were you seeing that on one of the plugs or all?
Have you ever changed out the distributor? They are known for wearing out.
Mike
Old 01-23-2013, 03:18 PM   #5
TwoFiftyShifter
Got it. Distributor cap and rotor. New ones in, fired right up.
Problem now is, a chinamen pissed on my floormat
1982 K10 SWB
Old 01-23-2013, 04:40 PM   #6
sntrym95
sntrym95's Avatar
Good to hear!
Chinaman is not the preferred nomenclature.
Mike
