01-21-2013, 05:42 PM | #1 |
Alternator Ext vs Int
I have a 71 C20 and I am considering replacing my externally regulated alternator with an internally regulated one. What are the pros and cons. I know I will need a different connector but what kind and where would be the best place to get the alternator and connector? Thanks for the assist
Kev |
01-21-2013, 05:49 PM | #2 |
Re: Alternator Ext vs Int
I would get a genuine rebuilt-by-Delco from O'Reileys or Advance or your local Delco distributor.
As far as connetors, on the alternator you can go buy a pigtail from a parts house, remove the connector, and swap onto your wires. At the regulator, just jumper outer to outer and inner to inner.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-22-2013, 05:10 PM | #3 |
The internal is more reliable & has a more constant voltage which will make the bat. & electronic equip. last longer.
01-22-2013, 05:18 PM | #4 | ||
"I ain't nobody, dork."
The main con is that the internal regulated alternators are more expensive.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
01-22-2013, 05:55 PM | #5 |
There used to be a step by step how to thread for converting to an internal regulator alternator, but after much searching I cannot locate it? I'm pretty sure it was in the F.A.Q. section. I converted mine and it worked great.
01-22-2013, 07:19 PM | #6 |
Thanks guys for all the info. This is why I love this site.
Kev |
01-22-2013, 09:07 PM | #7 |
laying low
This conversion is found in the truck faq section.
http://www.chevelles.com/techref/tecref14.html There are others on the net though.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-23-2013, 12:03 AM | #8 |
Here's another thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=119379
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
