Old 01-21-2013, 08:08 PM   #1
TIMAR
72 rear cpp sway bar kit
Was gonna mount this tonight, but got to thinking maybe not. Am doing a frome-off resto and there is no weight on the coils at the moment. Will This affect the location of the rear mounts to the trailing arms?
TIMAR is offline   Reply With Quote
Old 01-21-2013, 08:45 PM   #2
Andy4639
Old member
Andy4639's Avatar
Cool Re: 72 rear cpp sway bar kit
According to what I have read on it over in the suspensions threads you want the bar as horizonal as you can get it. So with the bed off yes it may not be perfect but once the bed is back on it should be close. It will be a lot easier to install now with the bed off though in my opinion.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-21-2013, 09:00 PM   #3
TIMAR
That was my thinking also(EASIER). Think maybe I'll ratchet strap the axle up to the frame a bit to replicate some load on it.
Old 01-21-2013, 09:19 PM   #4
70blackfish
Get pictures
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 01-21-2013, 09:28 PM   #5
Andy4639
Old member
Andy4639's Avatar
Here is mine.
