boosted
Can a brake booster be mounted directly to the firewall without a bracket unnecessarily pushing it out?
Re: boosted
Yes, but it will interfere with column shift linkage.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
Re: boosted
I've got a Lokar floor mount shifter with my TH350, so I should be good, I guess. I was thinking that maybe the plunger shaft would be shorter and that would somehow not have enough leverage to give good power braking. Thanks
#4 | |
Old member
![]() Quote:
Here is a link for them also. http://www.hotrodstrucks.com/store/c...customListIds=
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: boosted
It's funny you posted that. I just got mine today and was just looking at it!
Old member
I bought the copy a couple of weeks ago on the way to work on nights. I remember seeing it.
Re: boosted
Did you get my email?
#8 | |
The Older Generation
Re: boosted
http://www.67-72chevytrucks.com/vboa...d.php?t=347484 LockDoc
Old member
Re: boosted
LockDoc, I was just looking at that bracket this past weekend (thanks for that), and wondering why even that might be necessary. After seeing the Blazer in Street Trucks, I called Hill's and asked what the setup was--it's mounted flush, or looks like it in the photos. The owner is a very nice guy and was explaining how the MBM booster he used has a slightly different mounting position than others, so he redrilled holes, redrilled and lowered the pedal assembly inside and crafted his own plunger arm. He also fabbed a 7/8" thick plate to angle the booster upward--it's 1/4" thick up top--so technically his isn't flush with the firewall either.
I don't know that it's necessary to do that extra work if every other booster besides the MBM just bolts right on, and use CaptainFab's bracket. I'm just thinking it looks better without that deep, ugly bracket, and I'm running the straight six with the stock air cleaner, so I need the clearance. I hate the look of the offset I6 air cleaner that puts it over the valve cover...hate it. |
