Camber On A 66
Not having any luck with this in the search function... Looks like I've got a front-end camber issue on my 66. Is this something I can deal with on my own or would I be wise to take it to a shop? What's the process? Would appreciate comments from anybody with experience/insight.
Check out my BLOG to learn more about my truck project: CLICK HERE |
Re: Camber On A 66
make sure you have no worn out parts,tie rod ends ,ball joints,control arm bushings,etc .then take it for a four wheel alighnment
Re: Camber On A 66
Re: Camber On A 66
Will do... thanks for the input.
Re: Camber On A 66
Speedway sells a tool that allows the home user set the caster/camber of a vehicle. It is magnetic and connects to the drum or rotor face after the wheel bearing dust cap is removed. It is pretty easy to use and is really good for getting the caster/camber dialed in just where you want it. Alignment shops have a pretty wide tolerance to set to and for performance/bagged vehicles it is night and day in regards to the handling characteristics to have it set right. With that said it's important that you completely understand caster/camber before you start or you will go crazy adjusting and get nowhere. I have one and love it.....
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
Re: Camber On A 66
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 Last edited by KJSR; 01-22-2013 at 11:35 PM. Reason: slow net... |
