Old 06-11-2003, 02:00 AM   #1
72gmcshorty
72gmcshorty's Avatar
Horn troubles
What are common causes of horn not working? I have it plugged in, no blown fuses....
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-11-2003, 02:57 AM   #2
Alaskan
Truck'n the alcan
Alaskan's Avatar
1. Bad Horn, try using a jumper wire to see if it's good
2. Dirty or worn contacts in the steering colume
3. Bad horn relay
68 GMC 4x4
71 C20 Custom Deluxe
83 1/2 ton conversion van
Alaskan is offline   Reply With Quote
Old 06-11-2003, 04:25 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
4. horn slip ring.
I find that more often than not.
Old 06-11-2003, 05:39 PM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Yep, and it's usually the slip ring that you (or someone else) forgot to put back in... :p
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 06-11-2003, 05:47 PM   #5
Longhorn Man
LOL!
Interesting point on the slip ring for the non-tilt column, it has a tapered end that rides in the upper bearing race, and holds it all steady.
If you (or some one else) forgets it, you'll know bretty darned quick.
Old 06-11-2003, 07:01 PM   #6
72gmcshorty
What does that piece looke like? Is it that white plastic, circular piece with the little push button switch on it that comes off of the column? How do I test the above listed items? Is there some way to replace the contacts?
1992 Gmc 2wd
Old 06-11-2003, 07:35 PM   #7
71GMC_3/4T
71GMC_3/4T's Avatar
Yep, it's usually white or black plastic with a brass ring on it. There is a spring loaded thingy that contacts the underside of the "dish" that mounts to the wheel under the horn button cap.
If you short the wire that attaches to it, it should honk the horn, or at least click the relay. If the relay clicks, put the steering wheel back on. You're looking in the wrong place...
Lafayette, CO
