C10 Club Tennessee
Did Burb's only have two piece driveshafts?
Was just wondering if that is the only thing they came with? I have a 2 piece shaft and my burb is bagged. I have a 4L60E so I'm going to have to have it shortened a few inches. Was just wondering about the one piece.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
The Older Generation
Re: Did Burb's only have two piece driveshafts?
Yes, the suburbans all had 2 piece drive shafts, at least the 2 wheel drives. I don't know about the 4wd's but I would presume they all did too. LockDoc
![]() Join Date: Jul 2007
4 wheel drive have 1 piece.
Thanks Rock C
72 chevy 3/4 ton 4X4 |
Thanks for the update on that.
LockDoc
C10 Club Tennessee
Learn something every day.
Trying to decide if the original drive shaft can handle the 5.3. Not doing anything special to the motor so I think it should. Just get it shortened a few inches, install all new U-Joints, a new Carrier Bearing, and slap it in.
The drive shaft is plenty tough for 5.3L. U-joints should be checked though.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Two piece shafts were employed to stay out of the driveshaft "critical speed" range: the point at which the shaft starts to bend and swing around like a jump rope.
Critical speed is a function of shaft material and diameter, length (longer is worse), rear axle ratio (higher numerically is worse) and vehicle top speed. You can control all of that stuff in this case, so I'd recommend a one piece. I always use a one piece shaft whenever I can get away with it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jul 2010
My burb is 4x4 and has a 2 piece DL.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
My burb is a 4X4 - 3/4 ton and 205 transfer case.
What?
My '68 K20 has a 2 piece drive shaft.
From all of the 67-72 burbs I have seen, whether in person or in documentation all 2 wheel or 4 wheel drive were 2 piece drive shafts.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
My 72 k20 Burb has 1 piece 4" shaft , same as all my other 3/4 4wd .
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
