Old 06-11-2003, 02:49 AM   #1
WB72
Before and After
WB72's Avatar
Question Difference in 1/2 ton springs and 3/4 ton springs
Would I be able to put 1/2 ton springs in my C20 without any other modification?
I know that I wont have the load capacity, but I don't care about that.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 06-11-2003, 07:07 AM   #2
GMCPaul
Yes you can, the heavy duty 1/2 ton spring is exactly the same spring as a 3/4 ton in all aspects as they shared the same spring, so be sure you get a standard 1/2 ton spring and not a heavy duty, only difference in heavy duty & standard rear springs are the max weight ratings.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 06-13-2003, 06:53 PM   #3
WB72
Before and After
WB72's Avatar
Is that for the front or rear or both?
66,000 miles.
Alberta, CANADA
